carrots 1 Posted November 21, 2013 hi just about to buy a 20v turbo agu engine.do i need the box aswell got a 1.8 16v at mo Quote Share this post Link to post Share on other sites
marni 0 Posted November 22, 2013 hi mate get g60 gearbox or 2.0 16v iam runing g60 gearbox and engina putting out about 270 bhp so iam upgading to lsd depends how much power u gone use . the two boxs r good for 230bhp and maybe more Quote Share this post Link to post Share on other sites
vw bobby 10 Posted November 22, 2013 I am using 02a box out of a 1.8 16v, but the gear linkage is a 02j version out of a Mk4 golf 1.8T AGU on mine and its running 225bhp Quote Share this post Link to post Share on other sites
dragon green 5 Posted November 22, 2013 I've got an o2a diesel gearbox in mine (CTN) I'm running 262 bhp Your gearbox will be a straight fit,but you will run out of gears ! Quote Share this post Link to post Share on other sites
carrots 1 Posted November 22, 2013 i was going to use my 1.8 16v box but sounds like it wont last long then.just trying to keep cost down Quote Share this post Link to post Share on other sites
dragon green 5 Posted November 22, 2013 i was going to use my 1.8 16v box but sounds like it wont last long then.just trying to keep cost down If its in good nick,it'll be fine ! Quote Share this post Link to post Share on other sites
carrots 1 Posted November 23, 2013 i would say its in good nick,do you no if a vr6 clutch will fit the box Quote Share this post Link to post Share on other sites
GrahamU 6 Posted November 23, 2013 Trouble is 02a's are getting old now, whats the millage on the 20v box and is it cheap? Mine was only 230 brake and I have broken the 16v box I had to start with and a diesel box, I now have a box from an AUM Quote Share this post Link to post Share on other sites
carrots 1 Posted November 24, 2013 ive not got a 20v box,starting to think i should of bought a complete running car then stripped the bits off i needed Quote Share this post Link to post Share on other sites
dragon green 5 Posted November 24, 2013 I did have my CTN "freshened" up when I had the Wavetrac put in.and touch wood 2 1/2 years later,it's still doing sterling service ! Quote Share this post Link to post Share on other sites
carrots 1 Posted November 27, 2013 I am using 02a box out of a 1.8 16v, but the gear linkage is a 02j version out of a Mk4 golf 1.8T AGU on mine and its running 225bhp what clutch and flywheel are you using vw bobby Quote Share this post Link to post Share on other sites
carrots 1 Posted December 3, 2013 ive got an o2j box now,i am going to get a g60 flywheel and vr6 clutch next.what do you do about the slave cylinder and pipes Quote Share this post Link to post Share on other sites
GrahamU 6 Posted December 3, 2013 use the slave from your box, it fits the same on the 02j Quote Share this post Link to post Share on other sites
carrots 1 Posted December 4, 2013 (edited) good cheers,what about the driveshaft cups also will my 16v starter work with it Edited December 4, 2013 by carrots Quote Share this post Link to post Share on other sites
GrahamU 6 Posted December 4, 2013 get the cups from a 02j diesel box or some of the mk5 golfs use the 100mm cups, they are the bolt in type for these boxes not the circlip type on your 16v box, the cup come up on ebay but are usually expensive, I'm sure you could do a good deal at a breakers. The 02a starter will fit the 02j box Quote Share this post Link to post Share on other sites
carrots 1 Posted December 4, 2013 ok cheers for help.yer about £100 on ebay bit expensive Quote Share this post Link to post Share on other sites
Ron11 10 Posted December 5, 2013 Hello, i found 6 speed conversion 02a, 02j : http://www.eurotuning.cz/images/image/en/optimizing/index.html Quote Share this post Link to post Share on other sites
GrahamU 6 Posted December 5, 2013 Seen that before Ron, not cheap. The 02s 6 speed from a Touran is the same design as the 02a/j and can be fitted with a little modifying Quote Share this post Link to post Share on other sites
