Kempy 0 Posted January 8, 2014 Are they obsolete? Anyone making them? My valver is leaking and I've been advised its the hose. Thanks Quote Share this post Link to post Share on other sites
clumpy1 11 Posted January 8, 2014 Have you got a pic Ryan? I may have it;) Quote Share this post Link to post Share on other sites
twin45 1 Posted January 9, 2014 Got several second handones Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 9, 2014 you tried AVS? http://www.vwspares.co.uk/corrado_cooling.php Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 9, 2014 Doesn't show any prices or availability next to the 16v hoses Quote Share this post Link to post Share on other sites
clumpy1 11 Posted January 9, 2014 Did when I looked It was only a tenner Ryan Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 31, 2014 This is proving very difficult to sort.. Two hoses have been bought and they are both too narrow, what should the diameter be? Internal? Thanks Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted February 1, 2014 I've got a box full of hoses mate, also depends on the type of rad you have fitted. A/C or no A/C? Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 1, 2014 I'd prefer a new hose tbh, but it's a non.ac, manual car. Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 2, 2014 Hello Kempy, have a look on Ebay, item number 310827139167 bottom radiator hose OEM part n.o: 191 121 051E £13.40 with free delivery. Shows 4 are in stock. link: http://www.ebay.co.uk/itm/Radiator-Hose-Bottom-Vw-Golf-Jetta-Corrado-Passat-Gates-3113/310827139167?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222006%26algo%3DSIC.FITP%26ao%3D1%26asc%3D20181%26meid%3D4539551127462147622%26pid%3D100011%26prg%3D9057%26rk%3D3%26rkt%3D10%26sd%3D400610531881 Or as the other guys have said AVS sell this hose as well, their price is £9.90 takes 1 to 2 days for them to order it in, their part number is 3113 States it fits none air con and manual trans Corrado. AVS link http://www.vwspares.co.uk/corrado_cooling.php Hope this helps. Si Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 2, 2014 It's the same part both of those sites. A gates '3113' they reference the same part number as the hoses I've bought already and they were too narrow. I bought these. http://pages.ebay.com/link/?nav=item.view&id=350984749215 Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 2, 2014 Hello mate, cool fair play you've got one. The bottom hose with part number 191-121-051E this is normally used on most 4 cylinder 8v / 16v engines from the 1980s and 1990s mainly MK2 / MK3 Golf and the Corrado. Where as the top hose can be slightly different, between the 4 cylinder 8v / 16v engines. Part number 191-121-101P is for 2.0 8v (2E eng code - might fit ADY eng code as well) This is a longer hose than the 16v one as the 8v engines sit back further, so are closer to the bulk head but a little further away from the radiator. Part number 191-121-101AC is for 1.8 16v / 2.0 16v (KR / 9A eng codes) This hose is shorter than the 8v one above due to the way the alloy inlet manifold, folds up and over the front side of the cylinder head, so for this reason VW fitted a plastic triangle coolant housing, that pokes through between the inlet manifold branches, so making it a lot closer to the radiator. Just found this link for future reference for anyone that needs it. http://autopartmaster.com/en/?action=catalog_show&cat=vw&t_id=111258&added_=VOLKSWAGEN%20Scirocco/Corrado%201991 Hope this helps. Si Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 2, 2014 Length and shape is fine but it's the diameter that seems off. Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 2, 2014 Oh right ok mate, no worries. Cheers Si Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 10, 2014 Anyone got a tidy used one? Just as test? Thanks Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 17, 2014 Fairy urgent need one now. I'll try avs but I got a feeling it'll be too narrow again Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted February 17, 2014 I should have one. Can check this evening for you. Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 17, 2014 Thanks mate. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted February 17, 2014 Right kempy. I have one with the part no. 191 121 101 AC. Is that the one you're after? Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 17, 2014 Does your car have ac or an automatic? Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 17, 2014 That part number isn't the same as the part on etka/vagcat. 191121051E is the part number on parts catalogue, I've not got the hose, so I can't check the number on it. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted February 17, 2014 Manual and no a/c Quote Share this post Link to post Share on other sites
Kempy 0 Posted February 17, 2014 Can you take a pic? And measure the width? Might help? Thanks kempy Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted February 17, 2014 Here you go. Quote Share this post Link to post Share on other sites
