deamon90002004 10 Posted February 12, 2014 hey all, i want a stiffer suspension on my g60 (to stop it rolling onto it's door handles), but don't want a drop, i don't want to change dampers, just the springs, i do have early and late vr spring plates so can run pretty much anything whats about? im struggling to find anything Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 12, 2014 Some sort of block between each spring and clamped above and below. It'll stop the spring compressing as much but is a bit pikey tbh and will probably be a DIY job. Only proper option is a set of stronger (thicker) springs. Quote Share this post Link to post Share on other sites
swampy 0 Posted February 12, 2014 You can get a product from caravan shops that sits in between the coils and stops them compressing Haven't used them myself but remember my old man fitting a set to a talbot horizon back when we had family holidays in the caravan Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted February 12, 2014 As mentioned, you can get "Coil Spring Assistors" which may do what you want. http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_sop=15&_nkw=spring+assister&rt=nc&LH_BIN=1 Quote Share this post Link to post Share on other sites
Dox 23 Posted February 12, 2014 You need uprated anti roll bars to counteract the body roll, keep the same ride height and only a slight increase in harshness. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 12, 2014 hey all, i want a stiffer suspension on my g60 (to stop it rolling onto it's door handles), but don't want a drop, i don't want to change dampers, just the springs, i do have early and late vr spring plates so can run pretty much anything whats about? im struggling to find anything don't fit stiffer springs with standard dampers, they won't function correctly and will wear out prematurely. Standard springs with slightly uprated dampers can work well or matched kits and to control ride height preferably coilovers kits, but you get what you pay for in ride quality and longevity. Quote Share this post Link to post Share on other sites
