dawillabeast 10 Posted February 26, 2014 So I purchased this car last night after watching the owner start it numerous times, driving it for a bit, and giving it a good look over. Stopped on the way home and shut the car off and started it back up without issue. Went to start it today and nothing. Will not turn over. All electrical works, alarm works(arms/disarms) as it should. As I said this car has the Clifford Concept 650 MKII security system with the proof of professional installation done in 2008. Where this is my first Rado, and the first car I am considering a "project car", I am not too familiar with everything. I have a feeling it has something to do with the security system, even though it seems to be functioning properly. If anyone has any insight it would be greatly appreciated. I'll be uploading a few pictures shortly. Quote Share this post Link to post Share on other sites
easypops 8 Posted February 26, 2014 Could be the ignition switch, a common thing to go, had to do mine last year. You could try wiggling the key in the ignition to see if it'll start(sometimes helps). There is also an ignition switch bypass detailed on here somewhere which is very easy and would at least rule it out. I'll find the link later once I'm off my phone Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted February 26, 2014 Try disconnecting the battery for 30 secs, I had a starting problem with mine and that cured it. (Also have a Clifford) Rog. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 26, 2014 Don't forget you'll need to do a basic engine set up sequence if you disconnect the battery too. I had the same alarm for years and was fine till it was about 10 years old and then kept doing all sorts of sillly things so i just had it replaced with the up to date version and all is well again. Didn't want old wiring causing me issues while away somewhere. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted February 26, 2014 Don't forget you'll need to do a basic engine set up sequence if you disconnect the battery too. What's that all about? Rog. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 26, 2014 Every time you remove the battery or disconnect it the ecu goes into factor safe mode and sometimes doesn't run as smoothly of economically. Have a search on here. RW1 did a write up on how to do it. :) Quote Share this post Link to post Share on other sites
dawillabeast 10 Posted February 26, 2014 I was considering calling and having someone from clifford come out to take a look at it, but that costs a good deal. Has anyone had good luck with local garages working on security systems as complex as these? Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 26, 2014 I was considering calling and having someone from clifford come out to take a look at it, but that costs a good deal. Has anyone had good luck with local garages working on security systems as complex as these? Have a look if there is anywhere local recommended in here mate. http://the-corrado.net/showthread.php?t=15438 Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted February 26, 2014 Every time you remove the battery or disconnect it the ecu goes into factor safe mode and sometimes doesn't run as smoothly of economically. Have a search on here. RW1 did a write up on how to do it. :) Just founds it in the wiki, might explain my slight poor running when cold, cheers mate. Rog. Quote Share this post Link to post Share on other sites
paddy26 3 Posted February 26, 2014 Is the starter getting 12v when you try start the car? Did you try contact the previous owner and see if it was an issue they had seen before? Quote Share this post Link to post Share on other sites
dawillabeast 10 Posted February 27, 2014 sean - I looked through all 15 pages of that thread, but didn't recognize anywhere near me. I am fairly new to the area, so if you or anyone else knows of someone around the Bury St Edmunds area that would be welcome information. paddy - I have no way of checking voltage at the moment. I'll be towing it to a nearby garage where I can look over things more properly this weekend. Quote Share this post Link to post Share on other sites
n3p 3 Posted February 27, 2014 May sound silly, but IIRC my old clifford would sometimes require me to turn the key, then press unlock on the fob to de-immobilise the car before it started (there was usually a time frame where I could just unlock, get in and fire up but it would often fail). I'm guessing you've tried this? If not it's worth a shout. Having said that, I've had 3 cars with cliffords fitted and they were all problematic! Seems they have a shelf life. Good luck! Quote Share this post Link to post Share on other sites
dawillabeast 10 Posted February 27, 2014 So I had some time to really dig around today and I narrowed the issue down to the Ignition Switch. The security system and alarm are in perfect working order, and the Ignition Switch is solid in positions 1(off) and 2(run) but the connection must be going in position 3(start). With a little patience and a lot of force I was able to find the sweet spot and get it started. Thanks everyone for your help. Now I just need to get that Ignition Switch ordered and installed, but that shouldn't be too difficult. Quote Share this post Link to post Share on other sites
dawillabeast 10 Posted February 27, 2014 I looked around on here for an Ignition Switch, but can only find the Wiki article on how to replace it. The Wiki does have a part number for ordering through VAG, but I can't seem to find one. Any recommendations for a good site to order through? Quote Share this post Link to post Share on other sites
easypops 8 Posted February 27, 2014 Best to go to a dealer mate, or TPS? Quote Share this post Link to post Share on other sites
easypops 8 Posted February 27, 2014 Now I just need to get that Ignition Switch ordered and installed, but that shouldn't be too difficult. :lol: just wait to you get to that screw :lol: Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 27, 2014 Lol is this elusive screw that bad? Quote Share this post Link to post Share on other sites
