aaron-g60
G60 engine rebuild
Hi guys
Need abit of info on the best place to get parts from to do a top and bottom rebuild on my Corrado g60 (early)
It's on 170,000 now and is feeling abit tired.
Anywhere about that does specific kits ?
I would give Jmr a call and see what they suggest? Or jabbasport?
You could also check out bar-tek? They do loads of g60 parts
Have you done a compression test on your block?
I know OCD (Only Charged Dubs) do charger rebuilds but not sure if they do engine rebuild kits. Other guys I'd recommend talking to would be Stealth Racing or DG Autotech.
I had my bottom end rebuilt by stealth, very happy with quality of work and service, I will be using OCD shortly for my charger rebuild
Cheers
Scott
