stuarttaylor37 13 Posted May 31, 2014 I have read the how to identify dead top mounts thread but am more confused now than before I started My VR suddenly started clunking when turning right on hard lock (much louder than CV joint clicking)Car is on Koni's and lowering springs so hits bumps hard and crashy I've looked under the bonnet and both mounts look like this Is anyone able to tell me if they're the likely cause of the clonking? I intend to get it looked at but is it safe to drive? (carefully) Thanks for any input Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 31, 2014 They look ok, best to get the wheel off and jack up so it's not compressed. Could be a broken spring or trackrod end / ball joint Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted May 31, 2014 Thanks I'll take a look tomorrow and post what I find Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 1, 2014 (edited) Today I jacked up the car and removed the wheel-all looked intact I couldn't see anything obviously broken Spring looked intact but dirty I noticed though that the whole strut had dropped back down through so it was sitting back on the housing Compared to when the car is off the jack Is it meant to do that? Edited June 1, 2014 by stuarttaylor37 Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2014 Is the noise on full lock and moving forward or when stationary going lock to lock? Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 1, 2014 Hi Roger I've only noticed it when moving forward on full right hand lock- as I said much louder repetitive clonking than whenever a CV joint has worn I've just tried it when stationary and no noise Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 1, 2014 What condition are the rest of the suspension components like? Drop links or ARB bushes can clunk in a similar style to worn top mounts. That mount doesn't look especially worn. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2014 Any signs of the tyre catching on anything? Wishbone bushes ok? Find yourself an empty car park and drive on full lock until it knocks, then take a small amount of lock off - does it still knock? Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 1, 2014 What condition are the rest of the suspension components like? Drop links or ARB bushes can clunk in a similar style to worn top mounts. That mount doesn't look especially worn. The car has been standing for three years and history for five years before that is sketchy so I honestly cant say how old anything is. Passed an MOT in Dec last year When I looked today the bushes I could see looked intact and I tried moving the wheel hub around in all directions without any obvious play. I remember looking at the mounts a couple of weeks ago (comparing them against the ones on my 8v )and noticing that they were tight down against the strut housing tops as in the photo of the mount with the car jacked up. When I bounce the wing up and down I can see the strut top moving-should it be doing that? Any signs of the tyre catching on anything? Wishbone bushes ok? Find yourself an empty car park and drive on full lock until it knocks, then take a small amount of lock off - does it still knock? Wishbone bushes looked ok-from what I could see Tried that when I took a bit of lock off it stopped The faster I cornered the more readily it did it Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2014 Do you have equal amounts of lock left and right from centre? Turn to the left put a bit of masking tape on the steering wheel at 12 oclock with L on it. Turn to the right and do the same with an R on the tape. Back to the centre, have you got too much lock one side? Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 8, 2014 Seems to have equal amounts of lock Went for another drive and noticed something banging around on drivers side as well now Found this Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 8, 2014 Droplink's broken and ripped the CV boot, very rusty under there so maybe time to refresh a few bits! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 8, 2014 Yup Cars been standing a while! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 8, 2014 Sorry if its an obvious question but would the fact that the cars lowered and on konis stress the drop links and cause them to fail or is it more likely to just be corrosion? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted June 9, 2014 If the car is lowered equally left and right, then no, it won't stress the drop links as the arb should rotate independently to the wishbones. Likely corrosion and a cheap part combination is to blame here! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 9, 2014 Thanks Sean i'm going to order new ones from Vw today Are they easy to change? (I'm new to spannering but learning) I looked in the Wikki guide and the Bentley but couldnt see anything Cheers Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 9, 2014 Yeah they just bolt to the wishbone and unscrew from the end of the anti roll bar. Was the 1st thing that broke on mine. I'd soak it all in WD40 or plusgas the day before you plan to do it. It does help. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 9, 2014 Thanks Jim Quote Share this post Link to post Share on other sites
chazrad 0 Posted June 9, 2014 If you are sure that is the cause of your original knocking when turning the wheel, then great. But you might also want to check the state of the bush holding the steering rack in place. I too had a knocking when turning the wheel from lock to lock recently, and it transpired the whole steering rack was moving on the sub frame. An uprated (Powerflex) bush has sorted it. HTH Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 9, 2014 If you are sure that is the cause of your original knocking when turning the wheel, then great. But you might also want to check the state of the bush holding the steering rack in place. I too had a knocking when turning the wheel from lock to lock recently, and it transpired the whole steering rack was moving on the sub frame. An uprated (Powerflex) bush has sorted it. HTH I'm not sure of anything other than by the state of it it could all do with replacing! I'll fit the drop links and see how it drives-thanks for the tip though Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 13, 2014 (edited) I ordered VR6 anti roll bar drop links a couple of days ago and the VW dealer has told me that they are no longer available. Does anyone know of some good quality pattern brands as there seem to be a few available on ebay but prices are quite variable? Are the Meyle one on VW Heriage my best bet? Also need the bolt that holds them to the wishbone if anyone knows what sort to order that would be a great help Cheers Edited June 13, 2014 by stuarttaylor37 Quote Share this post Link to post Share on other sites
gNo 10 Posted June 14, 2014 You can buy the Meyle drop links from http://www.vwspares.co.uk. £4 cheaper than vw heritage. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 14, 2014 Ordered Thanks Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted June 22, 2014 Fitted anti roll bar drop links with new stainless bolts.... Went on to fix the loose exhaust heat shield and secured a loose clip on my 8V.....felt rightly pleased with myself. Took the VR for a drive and no more clunking around when turning.....until 5 miles into the drive the steering wheel started shaking like I hadn't tightened the wheel bolts. When I stopped there was smoke pouring from the nearside wheel caliper. I waited till it had cooled and then limped home, no wobble now but it was obviously binding. I stripped the caliper, the sliders appeared fine but I generally cleaned and re greased everything before reassembling it all. I went for a drive and that seemed to have cured it.....until the coolant light came on! I stopped, steam everywhere, no coolant and a slit in the pipe from the head to the matrix. Had to be rescued by the Mrs in her Ford! Instead of "What I did to my Corrado today" it feels more like "What my Corrado did to me today" Quote Share this post Link to post Share on other sites
Micky fletch 10 Posted June 24, 2014 Unlucky buddy Sounds like you had a shocker of a day. Hope everything hasn't put you off. Quote Share this post Link to post Share on other sites
