Blounter 10 Posted July 23, 2014 Heard a odd noise earlier and noticed the alternator belt was frayed and the tensioner sounded noisy. I'm sure there are posts regarding the belt change,but does the tensioner need a bolt in the threaded hole at the top? There seems a lot of movement on the right hand side of it? [ATTACH=CONFIG]79332[/ATTACH] Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 23, 2014 Someone will correct me if I'm wrong , but I think it's supposed to be without a bolt ? . Mine is the same . Quote Share this post Link to post Share on other sites
easypops 8 Posted July 23, 2014 Yes, you use a fairly long bolt(cant remember size) to release the tension, its not meant to be in there permenantly. If its making noise its likely that the bearing in the pulley is on its way out, my advice is to sort it ASAP as i left mine and it destroyed itself. The bearing itelf is very cheap as long as you feel confident enough to swap it out. I'll away and find a link to the bearing for you Quote Share this post Link to post Share on other sites
Jim 2 Posted July 23, 2014 Changing the bearing is extremely easy. I'm a complete wuss when it comes to spannering on my car but I did this repair about 15,000 miles / 3 years ago and it's been fine ever since. Someone even, very thoughtfully, turned it into a Wiki article :) http://wiki.the-corrado.net/vr6_belt_tensioner_pulley_repair.html Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted July 23, 2014 Further to Easypops post, it's a M8 bolt you need to release the tension. Quote Share this post Link to post Share on other sites
easypops 8 Posted July 23, 2014 Well done guys......didn't know that was in the wiki :) Quote Share this post Link to post Share on other sites
Jim 2 Posted July 23, 2014 It needs to be a really long M8 bolt too, to clear the fuel lines that sit right above the tensioner. They ideally want to be at least 4-5 inches. Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 Cheers for all posts……..yeah just found a post regarding the M8 bolt to release the tension so will have a go tomorrow. Tensioner and belt seem quite new though? Is it normal for the right hand side of tensioner to 'spring' back and forth,I presume so? Quote Share this post Link to post Share on other sites
Jim 2 Posted July 23, 2014 If you could upload a video illustrating the problem it'd be helpful! :) Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 If you could upload a video illustrating the problem it'd be helpful! :) Good call! leave it with me Quote Share this post Link to post Share on other sites
Dox 23 Posted July 23, 2014 Don't leave the bearing too long, I've got Grimmys old storm in the garage, engine cooked due to the seizure of the bearing in the tensioner, the plastic pulley melted to the bearing and massive over heating - coolant sprays out of the spark plug holes when cranked. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 23, 2014 Give me a shout if you want a spare tensioner to work on to exchange. Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 Give me a shout if you want a spare tensioner to work on to exchange. Cheers Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 Hers vid of tensioner. Doesn't sound to bad really. Not sure on movement. Notice that the belt slightly,one rib,overlaps end of alternator pulley though? [video=youtube_share;Y5hnvE71kHI] Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 ignore rough idle at end,air box removed Quote Share this post Link to post Share on other sites
Jim 2 Posted July 23, 2014 Doesn't look like the right belt.. there's no way it should overlap on the pulley. I reckon it must be the bearing going that's causing the vibration in the tensioner. Best thing is just to remove it and have a look - will only take 5 minutes to get off the car. And definitely change that belt!! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 23, 2014 Notice that the belt slightly,one rib,overlaps end of alternator pulley though? Looks like the alternator pulley alignment is off, which is probably what's frayed your belt and causing the tensioner to flap about like that. Either that or there's something odd with the belt. Count the ribs. There should be 7. Is it a proper Corrado alternator? Speaking of flapping about, that video demonstrates quite nicely why you shouldn't just replace the bearing. Over time the springs go weak lose control over the tension. Personally, I would replace the whole tensioner if you don't know it's history. I know it's not cheap, but it will ensure the belt is kept at the right tension. If it's a recent tensioner, then by all means just do the bearing but 100K plus, I'd be sticking a new unit on personally! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 23, 2014 You can remove one of the three bolts that holds the tensioner on and it fits into that hole to release the tension. Will be adding a new tensioner to my list then. Had planned to use an old one. The metal spring is pretty massive gauge so I thought it would be ok. Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 Doesn't look like the right belt.. there's no way it should overlap on the pulley. I reckon it must be the bearing going that's causing the vibration in the tensioner. Best thing is just to remove it and have a look - will only take 5 minutes to get off the car. And definitely change that belt!! Yeah cheers will have a scan tomorrow. Its been on a pit for most of the evening with blowing exhaust so hands covered in s**t anyway. ha! Passed Mot yesterday (just!) so not to down hearted. only needed rear brake pipes,steering gaiter,battery not secured,no cat,abs light not working……………..:bonk: Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 alternator ,belt and tensioner replaced by previous owner approx 13mths ago…………..correct parts though? answers on postcard pls Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 23, 2014 There is only 1 tensioner and only 1 belt (unless you have A/C), so the alternator is therefore the like suspect as there's a few different ones that fit VR6s. How many ribs on the alternator pulley? May only be 6 if the belt is over-hanging, which means it could be a 4Motion / R32 alternator. Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 There is only 1 tensioner and only 1 belt (unless you have A/C), so the alternator is therefore the like suspect as there's a few different ones that fit VR6s. How many ribs on the alternator pulley? May only be 6 if the belt is over-hanging, which means it could be a 4Motion / R32 alternator. Cheers kev. will check tomorrow in daylight………..and kopparberg is going down a treat at the mo. Euro parts do a Dayco belt,any views? Cant find one on GSF site Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 23, 2014 Good man! Car problems are always less severe when drinking :) I've used pattern belts in the past and they made some interested clattering noises after a few thousand miles. The OEM belt is the best but it's over 50 quid I think and they never keep them in stock. Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 Think I'll try a meyle one Quote Share this post Link to post Share on other sites
Blounter 10 Posted July 23, 2014 1290 sounds right length wise? no A/C Quote Share this post Link to post Share on other sites
