chefg60 0 Posted August 12, 2014 Hi I upgraded to 4 motion rear calipers and 280mm discs on rear, and want to fit carline cm6's on rear but face won't clear caliper, anyone shaved 10mm off caliper to fit wheels with low offset? Need about 15mm extra space can spacer to about 5 mm but anymore and they will just stick out too far. Cheers guys Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 12, 2014 Sorry can't help you with your query, but what did you have to do to fit 280 rears? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 12, 2014 I've shaved about 5mm off MK4 calipers to get 280s behind original speedos with no problems. 10mm seemed a step too far to me, but they're pretty chunky things. The original iron calipers aren't as chunky IIRC and might fit better? Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 12, 2014 Or what about a 5mm shave and a 5mm spacer? Do 280s go straight on the standard hubs Kev? I thought it involved a fair bit of machining.. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 12, 2014 Sorry can't help you with your query, but what did you have to do to fit 280 rears? X2 Quote Share this post Link to post Share on other sites
dragon green 5 Posted August 12, 2014 Kev had the same ones I've got,Eurospec,they are not vented,but you get a spacer to position the caliper to fit the supplied 280mm disc I had to shave the fins of my mk4 calipers to fit behind my 15" wheels [ATTACH]79447[/ATTACH] You can just make out where I "shaved" the fins ! Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 12, 2014 Arent they really highly priced though i cant remember exactly but im sure someone was selling some a while Ago and wanted about 280 quid and they set up needed new disks on top of that price ! Might be mistaken though Anyone got a linky Quote Share this post Link to post Share on other sites
dragon green 5 Posted August 13, 2014 Not cheap http://www.eurospecsport.com/products/brakes/performance-brakes.htm JMR does an in house 280mm vented rear disc conversion,but if IIRC you need a 17" wheel Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 13, 2014 Cheers mate , that is expensive , do you know why the jmr version need a 17 inch wheel ? I run 312s indee my sixteens with no problems Quote Share this post Link to post Share on other sites
clumpy1 11 Posted August 13, 2014 Matt your 16's were made to run big brakes being motorsport wheel's I imagine they suggest 17's to cover more wheel's. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 13, 2014 Point taken mate ill enquire with jmr i think Quote Share this post Link to post Share on other sites
clumpy1 11 Posted August 13, 2014 I could be wrong Matt JMR will keep you right.. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 13, 2014 wonder if John will do us a GB?? ;) Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 13, 2014 wonder if John will do us a GB?? ;) I'd be interested if he does. Although I'd be interested in him just returning my calls... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 13, 2014 Kev had the same ones I've got,Eurospec,they are not vented,but you get a spacer to position the caliper to fit the supplied 280mm disc I had to shave the fins of my mk4 calipers to fit behind my 15" wheels [ATTACH]79447[/ATTACH] You can just make out where I "shaved" the fins ! Yup, exactly that /\ ! Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted August 13, 2014 http://www.ebay.co.uk/itm/301076492967?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 available on the BAY Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 13, 2014 Thays not a bad price dude until you put postage on ( 155 ) Im assuming that kit uses the calipers already on the car and the disks are the only bigger bit about it ? Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted August 13, 2014 Thays not a bad price dude until you put postage on ( 155 ) Im assuming that kit uses the calipers already on the car and the disks are the only bigger bit about it ? Thats correct, you use the original calipers and it's the disc and spacers that's required to run the larger rear disc. Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 13, 2014 Thays not a bad price dude until you put postage on ( 155 ) Im assuming that kit uses the calipers already on the car and the disks are the only bigger bit about it ? Plus the import duty 4.5% and VAT ends up around £375 making it quite a costly upgrade... Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 13, 2014 Hmm i though it would be better to run bigger calipers So the pads are the same size and the caliper piston is the same size then the only thing your gaining is a vented disk ? More cooling ?? I know the backs dont do alot anyway not sure id like to fork out that much for cooler back disks ! But i like the idea of the brakes not looking so puney asthetically Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 13, 2014 Yeah that's probably about right RB you're only really getting a bigger disc, that's why I think £375 is big money. I'm in it purely for the aesthetics, as the big front discs and tiny rears look arse... Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted August 13, 2014 Surely there must be a cheaper option just to fit bigger disks It cant be that hard to knock up a set of adaptors for bigger disks Quote Share this post Link to post Share on other sites
Jamie 1 Posted August 13, 2014 (edited) I think the problem is the design of the hub is for taper bearings, whereas most modern/larger discs take cartridge bearings so it's a fair bit of engineering of the hub and/or discs to make it work. I'm pretty sure I read on here somewhere there's an old Toyota(?) disc that fits but can't for the life of me I can't find the post anymore... Edited August 13, 2014 by Jamie Quote Share this post Link to post Share on other sites
