robrado974 1 Posted August 26, 2014 Any body have these in a parts bin ? I have looked for the original sump gasket and it seems you cannot get them now , so I will have to get a rubber one . I've been told the early bolts on my 92 Vr will not be long enough . Many thanks Rob Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted August 26, 2014 What size (length) are yours Rob, I have the originals from my 94 VR6 that were stripped and re-zinc plated when I changed to the ally 24v sump and probably won't need them any longer, or alternatively replace with St/Steel instead? Ian. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 26, 2014 Who told you that rubbish? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 26, 2014 I did i think :lol: Thats what i was told and after talking to Vince when i dropped my engine off, i'm sure thats what he was also saying to me. I have a set of long and a set of the short bolts. But only ever seen thick rubber gaskets. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 26, 2014 Definitely rubbish then :lol: Seriously though, I've never had an issue with VR6 sump bolts with rubber gaskets or ally sumps etc. But just to be safe, I would just get a bag of generic 4Motion / R32 sump bolts from the dealer. VAGs all use ally sumps now (thicker flange thickness) therefore plenty log enough. I might even have a load of them in my "Drawer O' old vag ****" Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted August 26, 2014 Its true that the early vr used the fabric type gasket which used shorter bolts and the later rubber type gasket used the longer bolts Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 26, 2014 I ordered the wrong gAsket by mistake from AVS last year which was the fibre one Rob, so the gaskets (albeit aftermarket) can still be had too. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 26, 2014 Its true that the early vr used the fabric type gasket which used shorter bolts and the later rubber type gasket used the longer bolts I owe you an apology Mr Bowen. It's me who's talking rubbish :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 (edited) Right that's got that sorted lol ! Ian , I will be in touch on Saturday , I've ordered all my stuff , but they are getting the more gaskets in , they won't know which ones until they arrive . I take it the glue / mastic type stuff is used with both types ? Edited August 26, 2014 by robrado974 Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 26, 2014 The sealant is for use on fibre only Rob, although I don't think it hurts on the rubbers tbh mate. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 Thanks Sean , if the wrong gaskets come in with the order ie they only have rubber ones i will ring the company you metioned earlier . Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 Thanks Sean , if the wrong gaskets come in with the order ie they only have rubber ones i will ring the company you metioned earlier . Edit Tried looking online , AVS ? Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 26, 2014 No worries mate. Try VW spares Rob. It's the same company. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 Nice one Sean , thanks . Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 Sorry Sean , when i type in vw spares , then click on it it comes up with the link and then nothing ? Quote Share this post Link to post Share on other sites
borachris 0 Posted August 26, 2014 http://www.vwspares.co.uk This one? Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 26, 2014 That could be it Chris ? Proberbly is . Thankyou . Rob Quote Share this post Link to post Share on other sites
borachris 0 Posted August 26, 2014 I've used them before and loads of people have recommended them to me too. Quote Share this post Link to post Share on other sites
seanl82 23 Posted August 26, 2014 That's the one, yeah I'd recommend them too. Good service! :thumbleft: Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 27, 2014 Brilliant will ring them tomorrow . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 27, 2014 I never use sealant on the sump gasket. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 27, 2014 You don't need selant with the rubber gasket. Just make sure the mating surfaces are completely smooth and clean. The trick to it not leaking is making sure they're torqued consistently across all 25 odd bolts, and not over-tightened. It's quite easy to buckle the steel sump by over tightening the bolts, and then it leaks. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 27, 2014 I have sourced a fibre gasket now . Thanks for all the help , much appreciated as always . Ian , thanks for the offer of the bolts , it should be ok now . Rob Quote Share this post Link to post Share on other sites
