carrots
door membrane
hi got wet drivers carpet,the waters sitting on the top off the plastic sill carpet cover so it must be the door membrane.can you still buy them.cheers
Pretty sure they're available from Heritage, but it's just a sheet so you have to cut them to shape. Probably better off just finding something similar elsewhere for a fraction of the cost mate.
ive just looked on ebay they do a membrane foam you cut to size it looks like the stuff you put under laminate floor.i reckon a tube of butyl sealer should stick it
Not sure about using that . Go to bnq or somewhere like that and buy some thick plastic sheet , double sided tape , job done .
Renewed both door membranes a couple of weeks back and used eBay sourced clear 1000 Gauge polythene with black cloth reinforced tape. The window must have been replaced previously and the replaced membrane was not good to say the least (some sort of sealer - left a messy job).
I believe the stuff they sell from VW is just the foam membrane now anyways. I used foam on the VR and hasn't leaked yet :/
i bought some proper duck tape thats stuck it but its still getting wet.seem closer to the heater matrix side,ive changed that about 2-3 years ago tho and i cant smell antifrezze
