aposegil 0 Posted June 11, 2004 Basically where can i buy some :) as im starting up with the last of the boost pipes Also need to get a flexy joint like found on exhuast systems thanx in advance p.s Powerflow next to me doesnt want to know they are feed up of people taking the pi$$ with boost pipes so they wont do it Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted June 11, 2004 pheonix exhausts in cullompton devon would help you, bit far away from london though! Quote Share this post Link to post Share on other sites
aposegil 0 Posted June 11, 2004 pheonix exhausts in cullompton devon would help you, bit far away from london though! [homer] DOH [/homer] cool thanx mate but would either linke a internet base site to order the stuff from or somewhere a little more local not bothered if its in hertfordshire etc Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted June 11, 2004 use aluminium, not stainless. Quote Share this post Link to post Share on other sites
h100vw 0 Posted June 11, 2004 Go to another powerflow dealer. There must be one close by. Have a look on http://www.yell.com here's 2 http://www.yell.com/search/DoSearch?loc ... OCKHOLDERS Gavin Quote Share this post Link to post Share on other sites
aposegil 0 Posted June 11, 2004 nope the one close to me doesnt want to sell me the stuff next one like loads of miles away :( and i was going to give those two a call this weekend but ive go a feeling they dont do the flexy bend aswell lol Quote Share this post Link to post Share on other sites
stel g60 0 Posted June 11, 2004 al gimme a buzz after 6 tonight, ive got boost pipes and a flexy at home, dont know if its exactly what you need but as your down the road it could be worth havin a look Quote Share this post Link to post Share on other sites
g-master 0 Posted June 11, 2004 pheonix exhausts in cullompton devon would help you, bit far away from london though! :shock: i'm getting married in Cullompton in 2 weeks :) Quote Share this post Link to post Share on other sites
stevemac 0 Posted June 11, 2004 use aluminium, not stainless. I'm with you there Paul. Stainless tubes will retain too much heat & cancel out the effect of the intercooler. Highly polished aluminum will retain much less heat & the mirror surface will reflect most of the heat from the engine bay. Far better choice IMO. Quote Share this post Link to post Share on other sites
daves16v 1 Posted June 11, 2004 Aluminium also retains heat, which is why heatsinks are made from Ali. Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted June 13, 2004 Aluminium also retains heat, which is why heatsinks are made from Ali. aluminium doesnt soak heat it transfers it from the hotter plane to the colder plane so helps even the temps out. therefore it will help remove heat from the intake charge as long as the underbonnet temp is lower, but it doesnt retain heat well. heat up a bit of ali in the oven with a bit of stainless and see which one cools the quickest Quote Share this post Link to post Share on other sites
aposegil 0 Posted June 13, 2004 ok guys i understnad your points but i havent seen anyone that sells alu tubing and one got any contacts to buyt hte stuff from?? Quote Share this post Link to post Share on other sites
stevemac 0 Posted June 13, 2004 Your local engineering/fabrications company will sell you as much as you need - usually fairly cheaply too. Check the yellow pages. Best to buy from the smaller companies as the larger ones tend to be interested in contract work only. For a small cost they will usually bend or weld it to shape for you too. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted June 13, 2004 tube engineering unit 5 hurst end farm hurst end n.crawley buckinghamsire mk16 9hs 01234 391991 Quote Share this post Link to post Share on other sites
