Welsh g60 0 Posted June 14, 2004 I've just replaced the cat on my g60 with a straight pipe (cut the cat behind the lambda probe) and now whenever I change gear when booting it I get a huge backfire. Do I just need to adjust the fueling or is there more to it? Quote Share this post Link to post Share on other sites
steveo29 0 Posted June 14, 2004 mine doesnt do that....is it sealed well? Quote Share this post Link to post Share on other sites
kongo127 0 Posted June 14, 2004 That seems cool mate! 8) But not healthy for sure... I don´t have the cat too, but it doesn´t make that huge backfire! :shock: What i hear is some smooth poping from the exaust. I´ve kinda like it! :-P Check out your lambda probe harness because if it´s damaged the ECU will fuel up your engine to much! If possible check your CO2 Pot resistence too (500ohm). :idea: And if you have some time check the ignition timing too. It helped mine to stop to much poping... And i got more power from it! (advancing timing) Quote Share this post Link to post Share on other sites
bigbluec 0 Posted June 14, 2004 Mines done it ever since i bought it 2 years ago. Its to old to have a cat on it! (1990) i've checked the mixture and it's perfect the only thing i can come up with is a slight leak in the inlet manifold but after 35k + it doesn't seem to have hurt mine (touching wood whilst typing!). Quote Share this post Link to post Share on other sites
Welsh g60 0 Posted June 15, 2004 thanks all, I think I'll take it for a tune up and see how it runs after that Quote Share this post Link to post Share on other sites
