Monkey Boy 10 Posted February 14, 2015 Hi all, been an owner for 12 years but never really needed advice until now. I've just dropped the back axle out my 1.8 16V 1991 Corrado. A stupid question I'm sure, but does it have a rear ARB or has it been removed prior to me owning. Or is it simply the bar that runs in the crease of the beam? Pics on the net show a seperate bar fixed by straps around the beam. Assume these may be after market type? Quote Share this post Link to post Share on other sites
steveo29 0 Posted February 14, 2015 the bar thats fitted in the crease is your factory arb , the ones you see held on with clamps are aftermarket Quote Share this post Link to post Share on other sites
Monkey Boy 10 Posted February 14, 2015 Thanks Stevo, can it be removed or do you run it as well as? Quote Share this post Link to post Share on other sites
steveo29 0 Posted February 14, 2015 it stays on Quote Share this post Link to post Share on other sites
Monkey Boy 10 Posted February 14, 2015 Thank you! Just weighing up whether to fix one or not. Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 14, 2015 Put an aftermarket one on They handle so much better Quote Share this post Link to post Share on other sites
Monkey Boy 10 Posted February 15, 2015 Can you by just a rear one? What would you recommend? Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 15, 2015 (edited) Have a look on Demon Tweeks. There are 2 on there - H&R, and KW iirc. The H&R ones are generally well recommended. Edit: Eibach too. Not sure if they are available separately though. http://www.demon-tweeks.co.uk/performance/anti-roll-bars/car/volkswagen/corrado-vr6/1993/2-9 Edited February 15, 2015 by seanl82 Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted February 15, 2015 I've got an Eibach on mine, recommend it. Ian. Quote Share this post Link to post Share on other sites
dragon green 5 Posted February 15, 2015 I'm sure mines a weitech Quote Share this post Link to post Share on other sites
