Harrier
ABS warning lamp query
So, I noticed my ABS warning lamp wasn't working today, not really sure if it has ever worked though I would have thought I would have spotted it by now !?
I popped out the lamp this afternoon and was a bit confused by the fact there are 2 plugs into the back of the lamp and the top red 2 pin plug doesn't have any corresponding pins in the lamp ?
Does any one know if this is right or has someone removed that part of the lamp for some reason ?
In which case I will need another lamp,
the number on it is 535 919 235 BA
Thanks for any help
Daren
Yeah thats correct i think the US market used the top part for something like a check engine light
Ok, thanks Jon, so I guess I might be needing a new lamp then.:rolleyes:
Anyone know of any other cause of the lamp not illuminating?
Hi daren
unfortunately all me ba ones have gone sorry chief
Thanks anyway Chris, lets hope it's just a bulb.
My switch is exactly the same part number with exactly the same problem. I soldered a new lamp in a month ago, bingo it works. Never goes off now tho!! Its a cheap fix, just awkward to get a good solder joint without upsetting anything other joint on the circuit board
So picked up a bulb from Maplins and soldered it in, now working :)
Unfortunately it stays on all the time now :censored:
Terrific !
Welcome to the club mate, get vagcom on it, hopefully it will be a quick fix.
Btw mine stays on but goes off after a run, luckily it's 6 miles to the mot station....lol
Rog.
Well I put a multimeter on the wheel speed sensors and the nsf showed nothing. Replaced it this afternoon and the light didn't go straight out which concerned me, but after a 2 mile drive switched engine off and upon restart the lamp went out :):):)
