2tonedub 10 Posted June 28, 2015 As title im after a set of round hole g60 steels, not the later passat type with d shaped hole. Condition can be as rough as you like unless they are shaped like a fifty pence piece. Cheers Ross. Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted June 28, 2015 http://www.scottishvag.net/viewtopic.php?f=213&t=123091 Don't know if still available or if they are round holes Quote Share this post Link to post Share on other sites
2tonedub 10 Posted June 28, 2015 Thanks very much, will drop him a pm! Quote Share this post Link to post Share on other sites
2tonedub 10 Posted July 7, 2015 Still looking. Quote Share this post Link to post Share on other sites
2tonedub 10 Posted July 16, 2015 And again....... Quote Share this post Link to post Share on other sites
2tonedub 10 Posted August 14, 2015 Weekly bump. Quote Share this post Link to post Share on other sites
fendervg 29 Posted August 15, 2015 If it's the four bolt ones you're after they are dirt cheap from the stealers - I got a set for my MkII GTI a few years back. About €40-50 per rim, the trims will cost a bit extra. Quote Share this post Link to post Share on other sites
2tonedub 10 Posted August 15, 2015 The ones im after have been obsolete since some time in late 1992 mate, the ones you're on about are the later D shaped hole winters which as you say were still available until a little while ago. I already have a set of those ones. Cheers Ross. Quote Share this post Link to post Share on other sites
fendervg 29 Posted August 16, 2015 (edited) Ah. That's a pity. I'm pretty sure mine were round hole, but unfortunately I don't have a picture of the car with them on as it normally ran G60 BBS wheels. When you say "D shaped" do you mean the ones on the classic parts site? http://shop.volkswagen-classic-parts.de/vwcp/scirocco-corrado/corrado/chassis/rims/steel-wheel-passat-corrado-357601025q.html EDIT - mine looked like this in the attached pic - you'd be surprised what's still in stock in the dealer network - there was a rage on the VAG scene here in Ireland where people banded these wheels. A good dealer will be able to check stock in the rest of the dealerships in the UK and Ireland and on the dealer network in Germany. They should all be linked up together, assuming they know how to use the system that is. Good luck hunting. Edited August 16, 2015 by fendervg Quote Share this post Link to post Share on other sites
2tonedub 10 Posted August 17, 2015 I have had a couple of local dealers check before but as you say that assumes they know how to use the system properly which aound my way is a 50/50 chance! Quote Share this post Link to post Share on other sites
fendervg 29 Posted August 18, 2015 That's the way over here as well. Quote Share this post Link to post Share on other sites
2tonedub 10 Posted August 29, 2015 Managed to find a pair. If anyone has even single wheels or whatever give me a shout. Quote Share this post Link to post Share on other sites
2tonedub 10 Posted September 11, 2015 Weekly bump Quote Share this post Link to post Share on other sites
2tonedub 10 Posted September 22, 2015 Still looking. Quote Share this post Link to post Share on other sites
Adrian 0 Posted May 8, 2020 Hi Ross, I have 2 14" 16 hole g60 steel wheels dated 9/89 and 1/88. I assume since your post was 4 years you have aquired some. My question is they are in very good condition what are they worth today ?, As am trying to get price comparison on e bay and all I'm seeing is people punting D holed MK3 steels. (No 16 hole originals) Any advice appreciated. Adrian. Quote Share this post Link to post Share on other sites
Dox 22 Posted May 8, 2020 G60s had 15” steels to clear the front brakes Quote Share this post Link to post Share on other sites
