Stone0311
Discontinued? seals and gaskets - 8v G60
On the never-ending hunt for parts, I'm now trying to track down some seals and gaskets which are apparently discontinued - has anybody found a source anywhere?;
Locking cover seal N90250201
Charger support gasket 049127311
Oil filter bracket gasket 026115441A
Cheers
The first 2 images the dimensions of the seals are on the part number, 1st one is 63.5mm long by 5mm in diameter, if you search for an oil seal to ensure its designed to cope with the oil and temperature it will work instead.
2nd one is 26.5mm long by 2.5mm in diameter, same deal as the first one.
I can supply you the charger bracket seal if you need one, I bought a pack of 10 off eBay don't think I will use them all.
You could probably find the others from eBay as well, viton rubber O rings is the ones I went for. They've been for over a year so far.
This is them fitted.
