shawshankkid 1 Posted July 9, 2015 Hi all, I had a flat battery this morning so had alternator/ battery check...and the alternator is down. A quick question before I buy a new one. Would it be worth buying a new bosch voltage regulator and trying it first ? Or just buy a new alternator ? Whats your thoughts ? Many thanks Chris. Quote Share this post Link to post Share on other sites
MZpog 10 Posted July 9, 2015 (edited) I had the same issue with my alternator and for the sake of 2 screws, tried a new voltage regulator and it was just the same. It's still worth paying £10 for a new regulator before splashing the cash on an alternator. I ended up buying a recon alternator and now have one of these from ebay to keep an eye on things (its saved me once as the 1st recon alternator went duff). [ATTACH=CONFIG]81980[/ATTACH] Edited July 9, 2015 by MZpog Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 9, 2015 unscrew the regulator and take a look at the condition of the brushes first Quote Share this post Link to post Share on other sites
Dox 23 Posted July 9, 2015 Take the 2 screws out, look at the carbon brushes, if there's soot on the shortest one then its arcing across to the slip ring because its worn too short for a proper connection. Inspect the slip rings for deep scoring or even patches worn through to the fibreglass. If you decide to try a brush pack allow the brushes to wear in to the groves on the slip rings before condemning the alternator, its a bit like fitting new pads to used disks, they don't give full performance until they've bedded in a little Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 9, 2015 Thank you for the advise guys, much appreciated. Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 9, 2015 Should I get a bosch regulator or just get a cheap febi one you think ? Thanks chris. Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 9, 2015 Should I get a bosch regulator or just get a cheap febi one you think ? Thanks chris. I've used all sorts just fine. Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 12, 2015 Thanks for all the replies guys.....need a bit of advise please, I'm not entirely sure it's the alternator, I charged the battery overnight on a trickle charger and then left it in the garage.the next evening I tried to start it it was dead again, any ideas ? Get a new battery ? Thanks chris. Quote Share this post Link to post Share on other sites
Dox 23 Posted July 12, 2015 You can drain a battery to the point a home charger will not boost it up again. Fit and fling diagnostics is expensive, you need to do some tests with a multimeter to diagnose the problem. Make sure the battery connections are good, follow them to there opposite ends at the starter motor and the gearbox bellhousing making sure all are clean tight and connected Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted July 12, 2015 My alternator was also playing up awhile ago. I,d also recommend changing the regulator best thing I did and changed bushes at the same time. While I was at it gave the alternator a good clean serviced the adjuster bearings and fitted a new drive belt at the same time. Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 18, 2015 Thanks for all the help, it turned out it was the battery ! Never take the word as gospel from a garage, I got a second and third opinion and glad I did, bought a fuller 5 year guarantee battery. All is good now thanks. Quote Share this post Link to post Share on other sites
