robrado974 1 Posted July 15, 2015 As above , where have people bought from ? Which make ? .Im not sure if you can still get oem or not . As im replacing everything i will need a set of these . Thanks chaps . Rob Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 15, 2015 I'm still using them poly inserts the chap on here did. Was it jay? Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 15, 2015 Ive no idea Jim . Ive been looking at Euro parts , Heritage . Having not removed my engine or gearbox im not sure which ones i need . I presume its a front and rear mount and a gearbox mount, also the rubber subframe mounts . Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 15, 2015 I got Vibratech mounts Rob, which worked out very slightly more than getting OE ones from the dealer in the end. Quite a few "which engine mount" threads about so worth a search and read if you're not sure whether to go OE or not. If you do mix it up a bit, stick with standard rear and GB, and get a fast road front would be my recommendation mate. They were still available from the dealer last year, but certainly not cheap. A good branded aftermarket manufacturer would be sufficient. Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 16, 2015 Thanks Sean . I will get on to it . Quote Share this post Link to post Share on other sites
g0ldf1ng3r 14 Posted July 16, 2015 I got Vibratech mounts Rob, which worked out very slightly more than getting OE ones from the dealer in the end. Quite a few "which engine mount" threads about so worth a search and read if you're not sure whether to go OE or not. If you do mix it up a bit, stick with standard rear and GB, and get a fast road front would be my recommendation mate. They were still available from the dealer last year, but certainly not cheap. A good branded aftermarket manufacturer would be sufficient. pretty sure that's what I have on the VR too sean standard GB mounts & rear engine mount & then a VT front engine mount Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted July 16, 2015 I'm still using them poly inserts the chap on here did. Was it jay? Yes, Jay Renshaw. I have them too (plus his old "development" car!) and they are really good. Wonder if it is worth getting them remade? Ian. Quote Share this post Link to post Share on other sites
