Matt GTi
Handbrake light flashing.
I was giving my car some beans last night, and as i approached the redline in first and second, my handbrake light flashed on and off. Any ideas why? Perhaps it's a shift light that VW didn't tell us about! :lol:
I'd go with low brake fluid... check it and top it up if needed (don't fill it to the top though, as when you next change the pads you'll overflow it as you push the pistons back in! ;)
also if it keeps happening check your clutch slave, thats what mine did first but not on some others on here?!
According to Mr Manual...
The Warning Lamp comes on when:
(1) The Handbrake is on (duh!)
(2) The Brake Fluid level is too low
(3) With ABS it also indicates that the pressure in the pressure accumalator is too low
...Unless you're in my car where the led is bust :lol: I have the replacement, just not got round to fitting it :oops:
DtM.
fi the fluid level is fine..........i'd go with it being a dodgy sender in the cap.......mine did this when i first bougth it......and just gave the plunger a few movements up n down and its not given any problems since
