Guest petercabrio Posted November 7, 2015 This blue part of the water hose doesn't look right. Is it Quote Share this post Link to post Share on other sites
Dox 23 Posted November 7, 2015 Heater matrix hose? Mine has a plastic cylinder sandwiched by rubber pipes Quote Share this post Link to post Share on other sites
Dox 23 Posted November 7, 2015 The other is wrapped alloy sheathing, this one is an A/C car Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 7, 2015 Heater matrix hoses are the wrong way round and looks to me like some kind of repair. Quote Share this post Link to post Share on other sites
Guest petercabrio Posted November 7, 2015 I thought it was a repair and will it make a difference they being backward, it's a radiator Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 9, 2015 I believe they have an embedded bypass valve so yes it could matter that it's the wrong way round. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted November 9, 2015 whoa boys what car is the OP? it looks like a valver NOT a VR reason I say is that the matrix feed & return hoses come from different places on the 16v to the VR the VR has the feed hose cross over the return hose as per Dox picture on the valver the feed hose comes directly from the right hand side of the engine block & as such the hoses do not cross like they do on the VR I know this as I have recently replaced the matrix on my valver that said - the hose in the OP's pic looks like it needs replacing Quote Share this post Link to post Share on other sites
Dox 23 Posted November 9, 2015 Looks like a VR6 downpipe to me? Quote Share this post Link to post Share on other sites
Dox 23 Posted November 9, 2015 I believe they have an embedded bypass valve so yes it could matter that it's the wrong way round. There's not much room for a bypass in the end cap? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted November 9, 2015 Looks like a VR6 downpipe to me? that it does but best to check m8 :) Quote Share this post Link to post Share on other sites
Jim 2 Posted November 9, 2015 Also see the aux water pump... which would make it a VR. And the location of the ISV at the back of the manifold. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 9, 2015 Also see the aux water pump... which would make it a VR. And the location of the ISV at the back of the manifold. Think you're looking at Dox's pic Quote Share this post Link to post Share on other sites
Wullie 1 Posted November 9, 2015 As the OP has only recently bought a VR6 I would hazard a guess at a VR6. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 9, 2015 Mine had that grey / blue outer covering, it's just heat shrink to hold the pipe's shape I think. Either way, that one is split and the outer layer is bulging accordingly! Quote Share this post Link to post Share on other sites
Guest petercabrio Posted November 9, 2015 My picture is for a vr. Are the pipes the correct way round Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted November 9, 2015 As the OP has only recently bought a VR6 I would hazard a guess at a VR6. ahhh I didn't know that Wullie - thanks lol Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted November 9, 2015 My picture is for a vr. Are the pipes the correct way round I would say no they are the wrong way round on a VR the feed hose comes from the left had side of the block, as per Dox pic EDIT - although the matrix is essentially a radiator flow direction shouldn't matter BUT the valeo matrix I recently fitted definitely had an arrow showing flow direction - so it must matter somehow Quote Share this post Link to post Share on other sites
Jim 2 Posted November 9, 2015 Think you're looking at Dox's pic Doh :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted November 9, 2015 Heater matrix hose? Mine has a plastic cylinder sandwiched by rubber pipes this is how the hoses present & cross over Quote Share this post Link to post Share on other sites
Guest petercabrio Posted November 9, 2015 After all that, I bought some std hose and a connector so at the worst I could cut the bad bit out and repair I cut the blue sleeve off and the pipe was perfect underneath Then put them back as should be Do I need some heat wrap on the pipe? Quote Share this post Link to post Share on other sites
