stuarttaylor37 13 Posted December 9, 2015 Hi Anyone got any tips for fitting one? I removed mine and replaced it with a Topran one as part of a thermostat and housing kit as supplied by Tierod (Ebay seller) I took my time cleaning out where it fits into the block with a dremel so that it was as clean as I could get it. It was a really tight fit, I lightly lubed it with some silicone grease but the only way I could get it in was to line it up place a block of wood over the other end and tap it with a hammer. It eventually went in but shaved some rubber off the seal and after putting it all back together it leaks! Obviously got to do it all again but wondered if anyone had got any idea what I'm doing wrong or if the Topran ones are just not a good fit? Thanks Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2015 If it was still a tight fit after cleaning it up, id say you didnt clean it enough. Clean it till its smooth all the way around. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted December 9, 2015 I thought I'd done a pretty thorough job with a mini brass wheel followed by a few mins with a flap wheel Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted December 9, 2015 can you compare it to your old one? you shouldnt have to hammer it in lol Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted December 9, 2015 The old one was a VW one and had to be wrestled out, when I got it out the end just crumbled to bits Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2015 I thought I'd done a pretty thorough job with a mini brass wheel followed by a few mins with a flap wheel You prob did but worth double checking since you damaged the o ring. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted December 9, 2015 Yeah I'll check when I take it all apart again..I was wondering do I try another topran part, try an oe vw one or try a metal one with a few spare seals in case I cock it up again. I dont mind the cost, I just dont want to take the front off three times Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2015 Id go genuine about 30 quid. dont bother with a metal one not worth it when the drain plug on it fails. Quote Share this post Link to post Share on other sites
Wompa 0 Posted December 10, 2015 Who even uses the drain on the crack pipe? Just drain it from the lowest hose on the radiator ;) I got the Topran earlier... it was total crap! The thermostat house had a big gap in it because of the twisted ass plastic from factory. And the pipe didnt fit! Just like yours. Buy genuine or any other make... Meyle makes good parts! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 10, 2015 Metal one, the last one you will buy. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 10, 2015 I used fairy liquid to help mine fit and it was dam tight!! Quote Share this post Link to post Share on other sites
jekel 10 Posted December 10, 2015 The secret is heat the seal with a hairdryer before you put it in, applies anytime really but especially in winter, just feel differences in softness of rubber, put a Topran in before, just fitted a VW one on cold day and both push straight under hand pressure when warm, never hit them with a hammer or anything else, guarantee you'll wreck seal and it'll leak. If won't push in somethings wrong or rubbers too cold and not pliable. Little bit of WD40 does no harm, a little bit. Especially applies to the fuel pressure regulator thing, impossible in or out without heat. Hairdryer normally, warm don't toast it, hot air gun for hardened rubber suspension bushes if you use them. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted December 19, 2015 Thanks for the replies Today I fitted one of these http://www.ebay.co.uk/sch/a63yoh/m.html?_nkw=&_armrs=1&_ipg=&_from= Went in with a bit of lube and persuasion and no leaks Reccomended Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 20, 2015 Went in with a bit of lube and persuasion ed Oooooh sir!!! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted December 20, 2015 Everyone likes a tight fit on a Saturday afternoon! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 20, 2015 Phnarrr phnarrr :lol: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 20, 2015 Everyone likes a tight fit on a Saturday afternoon! Giggity Goo! Quote Share this post Link to post Share on other sites
