KARMANN 0 Posted March 2, 2016 For a 95 Storm. I've drained the system whilst fitting a new radiator. I presume it's the G12+ stuff I should be buying? How many litres should I buy? Any tips for refilling? Regards Fraser Quote Share this post Link to post Share on other sites
easypops 8 Posted March 2, 2016 Have a look here mate, about half way down the first post, past the electrical info there is a title about coolant http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide Quote Share this post Link to post Share on other sites
KARMANN 0 Posted March 2, 2016 Ideal thank you. iDisk do a search but never bothered reading that one as I though it was just about the fans and thermostats. That'll teach me. Fraser Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted March 2, 2016 For a 95 Storm. I've drained the system whilst fitting a new radiator. I presume it's the G12+ stuff I should be buying? How many litres should I buy? Any tips for refilling? Regards Fraser hi fraser when you get the G13 from VW the bottle has instructions on how to dilute & what ratio. it is on the label which you can peel back ;) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 2, 2016 I bought 2 X 1.5 litre of g13 recently. Used about 80 percent of it with distilled water. Quote Share this post Link to post Share on other sites
fla 9 Posted March 2, 2016 Give tge system a proper flush through. If you can get hold of some of the orange vw rad flush use that for a few hours. Drain, flush with clean water and refill. I popped the hose into the header tank on a slow fill and kept the drain valve on the crackpipe open and did this until the water ran clear. Then refilled with demin water and coolant. Its a slow process but useful to clear out rust and crud from the system. Quote Share this post Link to post Share on other sites
