mmacneill123 0 Posted May 9, 2016 (edited) Hi guys, Apols for the vagueness of this request and lack of a photo (atm) ...at the bottom rear of the engine, just above the join of the centre section and front of the exhaust, there is a meaty bracket with what I think was an 8-or 10-pin connector and another smaller connector right next to it. The larger connector has two of the pins separated off so you can only put the connector on one way. What are they for? The reason I am asking was the 8/10 pin one was pretty badly corroded on the contacts and one connector almost looked beyond repair :-) Edited May 9, 2016 by mmacneill123 Quote Share this post Link to post Share on other sites
Dox 23 Posted May 9, 2016 Its sounds like the lambda plug? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 9, 2016 Yeah, exhaust Lambda sensor and one of the sensors on the engine block (is it crank or knock sensor i think its called) Quote Share this post Link to post Share on other sites
mmacneill123 0 Posted May 9, 2016 Much appreciated guys, been having trouble with a O2 fault code, so that could explain a lot! Quote Share this post Link to post Share on other sites
fla 9 Posted May 9, 2016 Yep as above one is for the lambda the other for the knock sensor. Quote Share this post Link to post Share on other sites
