Guest sam1990rhodes Posted June 20, 2016 Hi, Was looking at doing the brake calliper upgrade on my rado at some point, was comparing the mk4 calliper to the 16v hub and noticed it appears like the calliper/brake pad would foul the brake disc? do i need anything to modify the front calliper to fit or do the below pictures look ok and im being stupid? [ATTACH=CONFIG]84027[/ATTACH][ATTACH=CONFIG]84028[/ATTACH] Quote Share this post Link to post Share on other sites
Dox 22 Posted June 20, 2016 (edited) Fronts? Originally using 288mm discs on the MK4? 4 stud hubs? If yes I believe you need 284mm Fiat coupe non turbo front discs, I've not done this myself, but it has been mentioned a few times on CGTi so may be worth asking on there for a definitive answer? http://www.eurocarparts.com/ecp/c/Fiat_Coupe_2.0_1999/p/car-parts/regular-service/car-service-parts/brake-discs/?10458007A&1&8d4ca3bb4afa565087942a5d6346b004dbce4c13&000027 http://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_1.8_1992/p/car-parts/regular-service/car-service-parts/brake-discs/?10444030A&1&2a9a235a83bc06046f05c7acb6dc2f29debe947d&000027 Looks like its not a straight fit, PCD and centre bore of the discs are both different and would need some machining (presuming I've searched the correct disc?). The usual upgrade is VR6 callipers and carriers (early MK3 golf or Corrado) and use a G60 front 280mm 4 stud disc which is a bolt on fit Edited June 20, 2016 by Dox Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 yeah they are 288m 5stud, so ill need 288m 4 stud for rado. I recall it being mentioned that you can get some polo brake discs that fit? Quote Share this post Link to post Share on other sites
Dox 22 Posted June 20, 2016 I've never heard of a 288mm 4 stud polo disc. You could try both MK4 or MK3 discs as there offset is different, both would have to be drilled 4 x 100 should the offset be correct Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 Hmm, looking at that its probably going to be easier for me to pick up some VR6 front callipers then, save having to get the discs machined each time i need to swap them!. Whats the correct offset if i was going to go down the mk4 288 route? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 20, 2016 I've fitted 312mm to a 4 Stud and machined the carriers (by around 3mm) and discs but these need 6mm spacing adding to them to fit a VR6 so in theory the 288's would need nearly 10mm removing to correct the offset (I think - could be completely wrong) Info here but pics have disappeared due to forum upgrades unfortunately. http://the-corrado.net/showthread.php?45434-312mm-Brakes-on-a-4-Stud You maybe best off looking at the 305mm Brembo conversion that was designed for 4 stud Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 all sounds very involved, suspect i may just go down the G60 brake calliper route if the 288mm mk4 caliper is a no go. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 The usual upgrade is VR6 callipers and carriers (early MK3 golf or Corrado) and use a G60 front 280mm 4 stud disc which is a bolt on fit is there any reason not to use the g60 front setup? so just use G60 calliper/carrier and disk? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 20, 2016 is there any reason not to use the g60 front setup? so just use G60 calliper/carrier and disk? It's the same stuff... If you're looking at second hand then the Seat Ibiza was the last model to use that setup (Lucas / Girling 54) Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 would these do the job: http://www.ebay.co.uk/itm/VW-GOLF-GTI-MK4-98-04-280mm-Front-Brake-Calipers-Pair-Kit-With-Discs-/381644376267?hash=item58dbc708cb:g:jNAAAOSwEOxXQJ5d Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 21, 2016 Just checked the caliper again, noticed the caliper was stamped with 54, does this mean they are the 280mm version? [ATTACH=CONFIG]84031[/ATTACH] Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 21, 2016 54 is the piston size but both the Lucas / Girling setup and the ATE setup are marked 54 This is why you can interchange these and not have to upgrade the master cylinder to keep the pedal feel. The one above is an ATE caliper from the MK4 style 288 / 312mm setup. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 21, 2016 oh ok, dam, thought id dropped lucky!. so does that mean im best picking up something like these from ebay they 54 but 280mm: [ATTACH=CONFIG]84032[/ATTACH] Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 21, 2016 They also look like 288's but you really need to buy something that lot a lot newer than that - they look f&*cked! Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 21, 2016 yeah agreed they dont look the best!. If they look like 288 too this may be whats leading to my confusion!. How do i tell the difference? Quote Share this post Link to post Share on other sites
Dox 22 Posted June 21, 2016 There's a set on CGTi in their classifiesd, collection only from Cambridge http://www.clubgti.com/forumdisplay.php?11-Classifieds Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 21, 2016 will drop him a message, cheers dox. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 21, 2016 are these 280 or 256 does anyone know: http://www.ebay.co.uk/itm/SEAT-IBIZA-2002-MK3-6L-1-2-12V-AZQ-O-S-DRIVERS-SIDE-FRONT-BRAKE-CALIPER-ONLY-/141892409574?hash=item21097258e6:g:dzYAAOSw--1WrpSf Quote Share this post Link to post Share on other sites
Dox 22 Posted June 21, 2016 are these 280 or 256 does anyone know: http://www.ebay.co.uk/itm/SEAT-IBIZA-2002-MK3-6L-1-2-12V-AZQ-O-S-DRIVERS-SIDE-FRONT-BRAKE-CALIPER-ONLY-/141892409574?hash=item21097258e6:g:dzYAAOSw--1WrpSf Neither, I suspect 239mm, you need to look for 2L engines and above for 280s as a general rule. Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 21, 2016 yeah agreed they dont look the best!. If they look like 288 too this may be whats leading to my confusion!. How do i tell the difference? I can't see the links so apologies if its been covered, but the 288mm calipers will have a triangular cut out at the top. The 280mm have a rectangular cut out, of sorts. Thats the best way to identify between the two. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 24, 2016 Alright ive picked some up from a mk4 tdi. What brake lines should I use? Looking braided. Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 25, 2016 You need conversion hoses. Mk2 - Mk4 is what its commonly advertised as. If you look on C&R enterprises they do the sets, or there are HEL ones on ebay iirc, as well as some others that are competitively priced. Or, you could just use standard mk3/4 Golf rubber hoses. They all have the same fitting to the copper pipe. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 30, 2016 I may have messed up.... brakes arrived other day, got round to opening them and the carriers appear to be part of the hub! argh!!. looks like ill be able to take the caliper off of the hub and theyll look like this: [ATTACH=CONFIG]84091[/ATTACH] Can i just pick up some G60 carriers or do i need a different calipers too? Quote Share this post Link to post Share on other sites
fendervg 30 Posted June 30, 2016 I have an old thread on here with all the part#s for MkIV rears (same on all cars) and 288s on the front for my VR. Quote Share this post Link to post Share on other sites
Dox 22 Posted June 30, 2016 I may have messed up.... brakes arrived other day, got round to opening them and the carriers appear to be part of the hub! argh!!. looks like ill be able to take the caliper off of the hub and theyll look like this: [ATTACH=CONFIG]84091[/ATTACH] Can i just pick up some G60 carriers or do i need a different calipers too? Nothing will fit your corrado. The good news is if the calliper slider threads in the hubs are OK (many are stripped) they're very sought after so you should be able to sell them on (NSF are like gold dust) to get your money back Quote Share this post Link to post Share on other sites
