edd
SEAT nuts and bolts part number - are they the same as VW
As title really
I need to buy loads of new nuts and bolts to put my refurbished VR6 subframe/crossmember/Radsupport/enginemounts on
I have a list of what i need from ETKA online
Trying to avoid driving 20 miles to local VW garage
I have found them all available online in terms of matching part numbers on a SEAT website SEATPARTSHOP.CO.UK
I am seeking opinion on wether they will be correct
However I don't really want to spend £40 on bolts if they are all wrong
Thoughts??
Edd
There is a lot of commonality throughout the VW/Audi/SEAT/Skoda ranges for things like nuts and bolts etc so as long as you are confident in the Part Nr's I would say that you should be OK Edd.
Ian.
parts numbers are shared/common between the big 5 brands (VW, VW CV, Audi, Skoda, SEAT) so if you've found the part number on VW Etka, provided it's been used on a SEAT, you should be able to order it from SEAT.
That was my though Ian
Just realised i can cross reference them from the SEAT part of VAG CAT online and the descriptions are indeed exactly the same so i am going to go with it....
Thanks for replies all. £60 quid on bolts including postage...eeeek!!!
Is that for the full front underside? I can't face looking at the bits on my phone lol, you wouldn't happen to have noted which ones are which, would you? :)
Me too, although I'm looking at the whole underside! I had a quick look at the website as well. I put drive shaft bolts in and they're almost £2 each. You need 12 of em! :eek:
I can put up a list of part number and descriptions that I bought when I get back to computer...
That would be great mate, much appreciated:)
A lot of the part numbers have changed, the lad from SEAT helpfully put the old part numbers on the individual packets of bolts i received
The ones i have tried so far seem to be correct
However I take no liability for any inaccuracy in the data below, please find my working list.
This does not cover every bolt, nut just the ones i wanted
Edd
