culshaw
PCV valve and associated pipework
Hi there
I'm after this, to see if it fixes a problem I'm having.
Anyone got one laying about?
Edited by culshaw
can't ****ing spell.
hi m8
IIRC they are very expensive from VW, or were if they are now obselete, as they only sell the entire section including the attached air housing
when i changed the PCV on my VR i got it from ford - as the v6 galaxy uses the very same part but ford sell it on its own
let me check my build thread for a part number for you.....
cheers but i need the pipes not just the valve itself as its been butchered
looking at the ford invoice it shows 7364573 & was £32.50+vat
sorry i should have been more clear - i understand you have the large plastic air intake section but need the hoses which connect the PCV to such
VW only sold the PCV with all of the air intake section you already have (IE the large plastic section which goes to the MAF & the TB)
ford sell just the PCV & likely sell the connecting hoses too
either way IIRC VW price was about £90 & as such i am sure you can get the hoses & a couple of jubilee's, or ones that can be made to fit, for less than £60
Do you need the vac lines to inlet and carbon canister etc?
I need everything that is in the picture at the top, the PCV valve on mine has been deleted and bodged together into the elbow via a straight line pipe
That's what I thought. The reason I ask is that there is more to it than pictured above. There is a series of lines that join the pcv, inlet and carbon canister.
ok, do you have a picture around?
