Miikeyboy 10 Posted September 29, 2016 Can anyone advise me on suitable springs for standard shocks?. I bought some Sach dampers and not sure what ones to get. Don't want anything too low or too expensive. From what I read would H&R be ok? Cheers Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 29, 2016 I'm quite happy with my H+R springs, plus they fit the late VR top mounts so no mucking about with different spring plates etc Had Pi and Weitec as well, but H+R have been the best so far Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 29, 2016 Great think I will get some ordered then cheers Quote Share this post Link to post Share on other sites
Cressa 44 Posted September 29, 2016 I'll 2nd the H&R. Although had to change to earlier vr mounts. Ooerrr. Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 29, 2016 When you say the mounts what bit do you refer to? Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 29, 2016 No6 i think. Mine definitely has the late no6 and no7 parts. Quote Share this post Link to post Share on other sites
Cressa 44 Posted September 29, 2016 I changed my no.7 for an earlier one. No 6 still fits ok with it. This is probably why mine were a good price Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 29, 2016 Hopefully they will be ok with my existing top mounts, will wait and see....cheers Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2016 What year and model corrado have you got? Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 95 vr6 Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 30, 2016 Same as mine, i'll try and find the receipt for the springs, i do remember they said Mk3 golf on them Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 Ok that's great cheers Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
Jim 2 Posted September 30, 2016 I've got some used KW lowering springs which came off my VR available. Not sure what I'd want for them (£30?), but if you were interested we could sort something out? Where are you based? They lowered the car approx. 40mm. Quote Share this post Link to post Share on other sites
Cressa 44 Posted September 30, 2016 [ATTACH]84643[/ATTACH] When I bought these they told they were for the late corrado and early mk3 golf. But this model did NOT fit the late spring plates, so check your numbers if ordering. I'm happy with them tho. Mine too is a 95 VR6 Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 Oh I see, Ill double check then before ordering thanks Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 I've got some used KW lowering springs which came off my VR available. Not sure what I'd want for them (£30?), but if you were interested we could sort something out? Where are you based? They lowered the car approx. 40mm. Hi thanks for reply not sure what I'm going to do yet but I'll Def get back to you if I decide these might be ok. How low do they make the car look? Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
volksworld13 0 Posted September 30, 2016 I've got two brand new late vr6 Spring plates if you need them surplus to requirements , bought from VW. A month ago. Plus two brand new genuine front bump stops. Quote Share this post Link to post Share on other sites
Cressa 44 Posted September 30, 2016 [ATTACH]84644[/ATTACH] That's mine with those springs and standard dampers Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 Looks good, and that's on the 30mm drop Ones yes? Quote Share this post Link to post Share on other sites
Cressa 44 Posted September 30, 2016 Yes mate Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Mystic Blue VR 10 Posted September 30, 2016 (edited) Used -30mm H&R springs with standard Sachs dampers on mine, with H/D Meyle top mounts & the standard, for my 96 model year, top mount plates I think. Sure they had MK3 Golf on the box too. [ATTACH=CONFIG]84645[/ATTACH] Edited September 30, 2016 by Mystic Blue VR Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted September 30, 2016 Just ordered myself the H&R ones as they look like they give just the look I'm after, cheers for everyone's advice Quote Share this post Link to post Share on other sites
Cressa 44 Posted October 1, 2016 What's the spring code of the ones you've ordered? Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Miikeyboy 10 Posted October 1, 2016 29872-1 Sent from my SM-N910F using Tapatalk Quote Share this post Link to post Share on other sites
Jim 2 Posted October 1, 2016 Hi thanks for reply not sure what I'm going to do yet but I'll Def get back to you if I decide these might be ok. How low do they make the car look? Sent from my SM-N910F using Tapatalk Like this: Quote Share this post Link to post Share on other sites
