Cressa 45 Posted October 5, 2016 Does anyone know what this connector is called/sizing and where I can get some from please [ATTACH]84665[/ATTACH] Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 5, 2016 Looks like a terminal pin to me, whereabouts did it come from? not sure which one but you can get them here (maybe) http://www.vehicle-wiring-products.eu/section.php/206/1/terminals-to-fit-mouldings Quote Share this post Link to post Share on other sites
Thursdave 10 Posted October 5, 2016 You'll be able to get it from any VW dealer. quite pricey though, around £5 for a wire (comes double ended) Quote Share this post Link to post Share on other sites
Cressa 45 Posted October 5, 2016 Thanks Jim. Thanks Thursdave. I've got one of those repair wires but want to crimp the cable straight onto my connections, not have another joint. .. I've ordered some 2.8mm ones so hopefully they are correct. I'm still trying to find what the 2.8mm refers to on these connections, or is it a different size Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Graphite 0 Posted October 5, 2016 Ev1 timer plug pins. Quote Share this post Link to post Share on other sites
Cressa 45 Posted October 5, 2016 ?!! Confuse 2 Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Graphite 0 Posted October 5, 2016 That's a common name for the connector that uses the terminal you have posted a picture of. They can be found in many of the connectors on the corrado, but the two pin plug (as used on fuel injectors for our cars) are called EV1 Timer plugs https://www.google.co.uk/search?q=ev1+timer+plug+pins&client=safari&hl=en-gb&biw=375&bih=559&prmd=sivn&source=lnms&sa=X&ved=0ahUKEwiE37vvq8TPAhURgx4KHdMsAr4Q_AUIBCgA&dpr=2 Quote Share this post Link to post Share on other sites
marks2 0 Posted October 5, 2016 The back of the connector looks like the type of Molex connector used in old style PC power connectors. I'm pretty sure I have the gen Molex crimp tool if you would like to borrow it. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted October 5, 2016 They are Junior power terminals, I used 3waycomponents when I was making my loom, nice guy and very helpful. He's online and on ebay. With a jago crimping tool I bought off Amazon, do a nice kit for a pretty good price Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted October 6, 2016 Junior power or "jp" terminals, available all over the net :) Edit just seen Daves post above. I've used 3way comp before too, would recommend. Quote Share this post Link to post Share on other sites
