GazzaG60 0 Posted May 29, 2003 Lee-As i mailed you i want 60mm not 52. tis 2 5/8 i think. I didn't hear back about it. Presumed you didn't have the numbers still. To recap i want a sport comp 20 psi with vac in 2 5/8 cheers Share this post Link to post Share on other sites
G60Jet 1 Posted May 29, 2003 leew, I'll phone the states Im after pro-comp ultra lites what are the other guys after!! Share this post Link to post Share on other sites
leew 0 Posted May 29, 2003 GazzaG60, Sorry I didn't get back to you but i was trying to keep it simple, just ordering the two types of gauges. Its got a bit OTT with people wanting different gauges. :shock: The 2 5/8 boost gauge will be £49 inc del. If this is ok contact me via my email regarding payment. Share this post Link to post Share on other sites
GazzaG60 0 Posted May 29, 2003 ill take 52mm if thats all that is available. would prefer 60 though sport comp boost 20psi with vac cheers Share this post Link to post Share on other sites
leew 0 Posted May 29, 2003 G60Jet, 6 off - Sport Comps 2 1/6 Boost inc vac 20psi 5 off - Sport Comps 2 1/6 AF meters 1 off - Sport Comps 2 5/8 Boost inc vac 20psi Share this post Link to post Share on other sites
G60 0 Posted May 29, 2003 you're sourcing them in the UK eh lee? not the states? if they're comin from the states i'll want in on this.. if not, there's no point for me. thanks Share this post Link to post Share on other sites
GazzaG60 0 Posted May 29, 2003 lee-i mailed you mate. Nigel-cheers for the legwork too. dubboy-installation is pretty simple really. AF need the signal tapping in to the lavinder signal wire in the loom coming from the probe. the wire is black then changes to purple.lav after the plug. follow it back into the loom a little away from the heat, splice in there. use solder. use the same ground as the probe(engine mount bracket) and possibly another too.need good earths these cars. tap power into ignition. make sure its a clean source. Boost can be tapped ito the vac line uner the dash to back of clocks with a t-piece Share this post Link to post Share on other sites
G60Jet 1 Posted May 29, 2003 6 off - Sport Comps 2 1/6 Boost inc vac 20psi 3301 Boost-Vac./Press 30 In. Hg.-Vac/20 PSI 5 off - Sport Comps 2 1/6 AF meters 3375 Air Fuel Ratio Gauge 1 off - Sport Comps 2 5/8 Boost inc vac 20psi 3401 Boost-Vac./Press 30 In. Hg.-Vac/20 PSI 1 off - Pro comp ultra lite 2 1/16 AF meter 4375 Air Fuel Ratio (Lean-Rich) Share this post Link to post Share on other sites
leew 0 Posted May 29, 2003 G60, Yeah the place i've found is in Blighty but Nigel might be able to source them in the states for cheaper. Share this post Link to post Share on other sites
G60Jet 1 Posted May 29, 2003 G60, We'll get a bulk shipment from the states to the UK so we'd have to send yours back unless we can get one lot sent locally or them all to you, then you send the UK lot to the UK!!! did that make sense!! OR State Guys G60, Europe Guys to G60Jet, UK guys toleew, Spain doesn't have a distributor!! Maybe i could get the license!!! Share this post Link to post Share on other sites
G60Jet 1 Posted June 5, 2003 Right The best i've got so far is 10% if we order a $1000 worth of stuff, still waiting on an email back the lastest company in the state, I sent all the details to including part numbers etc, and they emailed me back asking for the part numbers!!! :roll: so i wont be using them!!! anyway I'll let you know, im having better look on ebay with finding mine!! Share this post Link to post Share on other sites
G60Jet 1 Posted June 18, 2003 its fallen flat on its face for me to sort this. The americans want to big and order to make it worth doing. Looking this thread now if anyone wants it open again PM me or a mod DONT start a new thread Share this post Link to post Share on other sites
