Cressa 44 Posted November 30, 2016 My vr is at a local garage for its camber adjustment. The fitter has said my bolts in the lower part of the suspension leg are wrong !!! As they don't adjust the camber. Q - should it have adjusting bolts/nuts? I thought they were just normal high tensile straight items, not adjusting ones! ! I've only swapped the old ones across so I suppose they could be incorrect. All answers greatly received Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 30, 2016 The camber is adjusted by the strut to the hub knuckle. The bolts just hold it in place so the straight ones are correct. You can get camber adjusting bolts but they're aftermarket. Quote Share this post Link to post Share on other sites
Cressa 44 Posted November 30, 2016 That's what i was telling him, but he was questioning it shouldn't be like that. ... Glad I'm not going mad with with everything I've read. Thanks mate Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted November 30, 2016 Yeah, as Sean says, the straight ones are the factory ones. I've got a set of the after market "adjuster" ones on mine though. They are cheap enough to buy if you wanted to change over. Sent from my iPhone using Tapatalk Pro Quote Share this post Link to post Share on other sites
mic_VR 3 Posted November 30, 2016 Just get him to dial it all the way in on the top bolt, all the way out on the bottom one, and you've got that touring car look! :norty: Quote Share this post Link to post Share on other sites
Cressa 44 Posted November 30, 2016 😁Thanks Gents Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
odub 0 Posted November 30, 2016 Carrying on with camber. What is recommended camber for fast road driving? I've put mine together and set it to maximum -degrees but need to get it all setup soon Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 30, 2016 Think factory is -0.5 degrees but for a bit more "sporty" handling iirc -1 is as much as you need without going mad. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted November 30, 2016 ^^exactly. -1deg will be enough, that's where mine is set and it turns in lovely on road and track. Had it set at -1.5 once.. great turn in, wanted to wander in a straight line. Quote Share this post Link to post Share on other sites
