ryan_welshman 10 Posted December 29, 2016 Hey people Got a major problem where i keep getting a major battery drain and just wondered if there are commons faults to look for? Its fitted with uprated headlight loom by previous owner as an fyi Any help would be great Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 29, 2016 Check all earth's in engine bay, plus check glove box and boot light aren't staying on. My old valver had an eBay headlight loom fitted, and that caused a battery drain for me. Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted December 29, 2016 Check all earth's in engine bay, plus check glove box and boot light aren't staying on. My old valver had an eBay headlight loom fitted, and that caused a battery drain for me. Im assuming that you then replaced the headlight loom then? Can you recommend a good replacement? As the headlights are still crap haha Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted December 29, 2016 Put a meter across the battery and the negative cable and measure the current flow. Then start pulling fuses until the current drops. You'll then be able to identify the drain. Culprits include the boot lock light switch, door lock actuators and glove box as above but yours could be something different. You'll get it sorted soon, I'm sure. Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted December 29, 2016 Cheers guys. Plenty to keep me busy! Sent from my SM-N9005 using Tapatalk Quote Share this post Link to post Share on other sites
Mystic Rado 0 Posted December 29, 2016 Mine had an issue with a Sony head unit - if you didn't turn it off completely, no stand-by light or owt, it killed the battery well dead. Same head unit in my Mk2 GTi, same problem. But as above, could be any number of things. Good luck sorting it out. Quote Share this post Link to post Share on other sites
