Spuddy
Gearbox codes for those who are engine converting
Hi guys, for any of you that are thinking of converting your car either engine swaps or just a gearbox upgrade/swap after a failure, you may find this information useful.
Its direct from my volkswagen etka parts system so is accurate information.
I will display different categories for platfrom of cars to hopefully make it easy to understand.
Please remember these are the final drive ratios so will affect the gearing in as much as what Rpm you will be doing at say 70mph. Handy for working out the cruising speeds you desire.
The gear ratios are different and the codes will differ for longer 1st, short 2nd etc. This all gets very complex but to get a idea of what you are looking for this should help.
Lower ratios are better for a low engine Rpm at cruising speeds
Starting with mk3 golf/vento
02A 5 SPEED TRANSMISSION
GEAR RATIO N.O. Of TEETH CODES
3.15/1 60/19 CTN, ASD, CYP
3.38/1 61/18 CCM, CHN
3.64/1 62/17 CDM
3.68/1 70/19 CDA, DPA
MK4 PLATFORM 02J 5 SPEED TRANSMISSION
Golf bora leon octavia A3
3.38/1 61/18 DEA, DQY, EBF, EGS, EBJ, EGR, EUH, EWX, EHC, EWW, DZC, JDH JEJ, JDM
3.64/1 62/17 EHA, EWU, EXE, EXD
3.68/1 70/19 EVS, EGY, FBX, EBN, ENJ, JEG, JDP,
3.94/1 71/18 EBA, DZL, EGC, EMR, EGU, EBS, EHB, JDW
4.24/1 72/17 DYN, CZM, EBD, EGV, EGT, FBV, EWG, EBM, EGW, EVQ
So far I have done this. I will add the 02M 6 speed box codes when I can and also all the rest of the 02A numbers for the corrado platfrom as that will help sourcing suitable standard replacements.
Thanks
P.s, this may not display as logically as I had hoped if you view in Tapatalk
Sent from my D6603 using Tapatalk
Edited by Spuddy
I can't view the link for some reason, maybe it's my Tapatalk. But I'm happy if it stays as may serve someone well in the future!
Why would you remove it?
Because the OP might not want it on his thread?
My MK4 Golf GTI 1.8i 20v Turbo has a ENJ code gearbox. Looking at the list above, could i fit an EVS code gearbox in it's place?
