lilfuzzer
Various corrado parts
Have a few bits for sale all items are priced collected but can post at cost
[TABLE=width: 564]
[TR]
[TD]ECU 057 906 022N[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]ECU 8A0 907 404 L[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]Dizzy 237 521 046[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Brake Servo 258 614 105[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]VR6 damper box provisionally sold[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Number plate light surround aqua blue[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Fuel fillar cap aqua blue[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Brake master cylinder and tank 10.6123-0680.3[/TD]
[TD]30[/TD]
[/TR]
[TR]
[TD]ATE brake master cylinder[/TD]
[TD]35[/TD]
[/TR]
[TR]
[TD]Accelator pedal[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Window Module 191 959 875[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]20[/TD]
[/TR]
[TR]
[TD]Window Module 191 959 875 X[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Passenger side dash vent housing[/TD]
[TD]5[/TD]
[/TR]
[TR]
[TD]Window reg motor without cables[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Fuel pump 191 919 051 AT[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]brake light switch 191 945 515 [/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]brake light switch 191 927 189 D[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Spoiler switch[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Early fog light switch[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]10[/TD]
[/TR]
[TR]
[TD]Early rear window switch[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]10[/TD]
[/TR]
[TR]
[TD]Headlight switch[/TD]
[TD]20[/TD]
[/TR]
[TR]
[TD]Early sunroof switch[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Early mirror switch[/TD]
[TD]10[/TD]
[/TR]
[TR]
[TD]Spoiler relay 535 919 845 B [/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]15[/TD]
[/TR]
[TR]
[TD]Gear shifter gairtor and grey surround[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Late drivers door handle with switch[/TD]
[TD]15[/TD]
[/TR]
[TR]
[TD]Speedo clocks 535 919 035 AH/ 535 919 042 G[/TD]
[TD]35[/TD]
[/TR]
[/TABLE]
Do you have the driver side electric windows switch for 94 VR?
Ok mate to confirm its the inner grab handle
Sent from my SM-G357FZ using Tapatalk
Hehe, sorry my mistake, thought it was the outer! :-)
Hey lilfuzzer ........ do you still have the 'Brake master cylinder and tank 10.6123-0680.3' ? ............ mines on its way out and its time to fix ....... cheers .......... Stevefromcov
Yeah pal still here it's yours if you want it
Hi Chris
Do you have a decent 90mm splitter hanging around ?
The ones I have someone has claimed them but if fails through I'll let you know
Is the fuel pump the in tank one and does it fit a VR6?
If so I will take it if it's still available?
Thanks
Unfortunately it's not mate it want for a vr
Gutted. It needs to be for a VR. Thanks anyway.
