VR-OOM 0 Posted July 24, 2017 Looking for 323 x28mm Corrado offset brake disc, recommendations gladly received. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted July 25, 2017 I have no experience with this but I thought you could use Seat cupra discs. Anyone? Quote Share this post Link to post Share on other sites
odub 0 Posted July 25, 2017 which calipers are you using? Quote Share this post Link to post Share on other sites
odub 0 Posted July 25, 2017 Saying that, I have a 323 5x100 disc spare that you could try Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted July 25, 2017 I've got 4 pot Brembos, I have a set of Leon discs which I thought were for a cupra but the offset is wrong. Quote Share this post Link to post Share on other sites
neil20vtc 0 Posted July 25, 2017 I have the Leon cupra r brembo setup on mine and fitted i think 6mm spacers between the hub and carrier so the caliper lines up with the cupra r disc think this is the norm due to the differences in the two cars hubs longer bolts to make up for the spacers is also advised Quote Share this post Link to post Share on other sites
GrahamU 6 Posted July 25, 2017 Have a looky on here http://www.brembo.com/en/Varie/Brembo_SportBrakeDisc_ApplicationList.pdf its a pdf so you can can save it hen search the size you want quite easy Quote Share this post Link to post Share on other sites
