robbystick 10 Posted November 17, 2017 Hi everybody, Started up my project car: 2.0ltr 16v With abs - K reg, only for it to idle badly and smoke horribly. Found that brake fluid was being sucked into the engine via the vacuum pipe from the servo, master cylinder leaking from the rear seal. Trying to find a new master cylinder and servo (and pipe) with no success, anybody got any ideas where to get one or second hand units? Appreciate any help you can give. Rob Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted November 17, 2017 Join the club, I've been trying for months. Finally had one, and my Hermes lost it. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robbystick 10 Posted November 17, 2017 Ah! Not good. I suppose thare must be some company that can overhaul thse items , somewhere? I don't understand what is so specialised about these bits of kit that makes them unobtainable...... Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted November 17, 2017 Past Parts can refurbish yours for about £160 i think. I can't get mine out is the problem as I live too far from where my car is stored. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted November 17, 2017 Probably doesn't help, but I have one removed from a K plate Mk3 Golf VR6 with ABS. Will try find out if it's the same. https://www.ebay.co.uk/itm/253254032829?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Quote Share this post Link to post Share on other sites
Dox 23 Posted November 17, 2017 I don't understand what is so specialised about these bits of kit that makes them unobtainable...... The holes that attach the master to the servo are on the slant, so you need a master to suit the ****ed up studs on the servo limiting options and from a suppliers point of view sales are limited. You cant swap the servo for a more conventional set up as you need the hole for the pedal position sensor unique to our crappy ABS set up Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 17, 2017 I have a servo mate Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted November 17, 2017 The part number for the abs models is 358611019D which is 23.81mm. The smaller 22mm has a very similar part number so be sure to check if you come across one. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robbystick 10 Posted November 18, 2017 The holes that attach the master to the servo are on the slant, so you need a master to suit the ****ed up studs on the servo limiting options and from a suppliers point of view sales are limited. You cant swap the servo for a more conventional set up as you need the hole for the pedal position sensor unique to our crappy ABS set up Thanks for the info, although it was kind an ironic question...... Cheers Rob Quote Share this post Link to post Share on other sites
robbystick 10 Posted November 18, 2017 Thanks for the part number info, I know that very careful attention to these pays dividends in the end. Cheers, Rob Quote Share this post Link to post Share on other sites
robbystick 10 Posted November 18, 2017 Hi Lilfuzzer, I think I got a lift pump and sender from you about a year ago, you ok? Got a price including postage? Does it have the pipe on it? Thanks Rob Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 18, 2017 Hi Lilfuzzer, I think I got a lift pump and sender from you about a year ago, you ok? Got a price including postage? Does it have the pipe on it? Thanks Rob Hi mate will get a picture mate I will also check for a pipe dude 👍 Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 22, 2017 Have a few in the box mate the second one is from a j reg 2 litre 16v Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted November 23, 2017 Hi Chris, do any of those master cylinders still have the part numbers on? The second one looks very very similar to what I'm hunting for. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
robbystick 10 Posted December 22, 2017 Seasons Greetings and all that, I have had a look at my master cylinder and there is a yellow plaque with two numbers on it a shorter one on top and a longer one below that. Do you know which one might be the part number? Cheers Rob Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted December 22, 2017 Hi Chris, do any of those master cylinders still have the part numbers on? The second one looks very very similar to what I'm hunting for. Sent from my iPhone using Tapatalk Hi mate just seen this the one from my green vr didn't match the number you needed mate Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted December 22, 2017 Seasons Greetings and all that, I have had a look at my master cylinder and there is a yellow plaque with two numbers on it a shorter one on top and a longer one below that. Do you know which one might be the part number? Cheers Rob Hi Rob If you can send a picture I can try and match up Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
Mystic Rado 0 Posted December 23, 2017 Been mentioned already, but if you're really stuck, Past Parts will refurbish your existing master cylinder. They bore it out and re-sleeve it with stainless steel. It was the only reliable option I could find for my VR6 bearing in mind that all Corrados are over 20 years old now and the VR6 master cylinder, at least, is obsolete from VW. Quote Share this post Link to post Share on other sites
robbystick 10 Posted December 24, 2017 Thanks Mystic, I had a look at their website and seems like they do a really pro job but I,m short of dosh at the mo. Cheers Rob (Merry Xmas) :-) Quote Share this post Link to post Share on other sites
robbystick 10 Posted December 24, 2017 Hi mate, i’ve Got one from someone else on the forum, the servo part number is ok, but there are two numbers on the master one matches mine but the other doesn’t so just trying to make sure, as there so many different ones. Cheers and merry Christmas, Rob Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 30, 2018 I've been trying to find a replacement brake master cylinder for my Corrado 2.0 16v, I phoned my local VW Dealer and they checked all the dealerships in the UK, but all sold out now, they said the brake master cylinder for ABS went obsolete in 2010, there were a few left up until about 2012, but like I say they're all gone now. Apparently the Brake master cylinder for ABS was originally £350 new from VW Amazingly VW still stock the NONE ABS master cylinder for the Corrado cost is £270 But only have a few left. I've managed to get a secondhand master cylinder for ABS off Ebay for about £60 as my original one on my Corrado is showing signs it's on the way out. Because some of you guys have mentioned that you possibly can get it overhauled from a company called PAST PARTS. I decided to phone them up and spoke to a guy called Richard, he confirmed that they have done a few Corrado master cylinders in the past few years, he told me amazingly that he's got a Corrado master cylinder for ABS already done on the shelf, but that he would need the old unit for exchange, otherwise a surcharge is added on. Richard said to overhaul the Corrado master cylinder for ABS is £105 + VAT Also he said they can overhaul the original clutch master cylinder for £65 + VAT Apparently they rebore out the master cylinder and fit a stainless steel sleeve, so they're still able to fit the original size seal kit. Plus they will powder coat the master cylinder in black so it looks OEM, but this is optional if you want the OEM look or not. Time wise he said roughly about 2 to 3 weeks as they are very busy at the moment. Basically when you send your old item to them, add a note of what you want them to do and your own address, and when completed they'll phone you to let you know your item is on it's way back. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 30, 2018 I'm going to send off my spare master cylinder later on this week to them. If anyone else needs one ASAP, Richard at PAST PARTS has one already done on the shelf. Si Quote Share this post Link to post Share on other sites
Daveproyoyoyo 10 Posted July 30, 2018 I had mine done by them a few months back now and they were really good. I spoke to someone called Nigel on the phone who was exceptionally knowledgable, we spoke for a good 20 minutes or so. We even ran into a few issues with the master cylinder I sent to them which they sorted out quickly a well. Generally I think they were awesome and the only criticism would be that the powder coating they did could have been better, it is a little patchy in places. Everything else they nailed. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 4, 2018 Hello mate thanks for reply, yeah I've sent my spare master cylinder to them, so will see how it goes. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted September 28, 2018 Just had a phone call from Past Parts, my overhauled master cylinder is now ready, so should be getting it back on Monday 1st October 2018. They've been delayed doing the job as had to wait for another batch of the seal kits to come in. Cost is £109 + VAT £21.80 + Postage £6.59 = Total £137.39 This was for a 2.0 16v one. Si Quote Share this post Link to post Share on other sites
