vr6paul 0 Posted February 4, 2018 Folks sorry I know it’s been asked loads but I’ve been searching round looking for where to source a low temp thermostat and fan switch for my m plate vr6. Has anyone got any part numbers to help? Or somewhere to source. Saw something on awesome gti but thermostat was £50! I’m hoping to get car back on road and engine temps I remember concerned me so these wee mods may help. Any chance? Quote Share this post Link to post Share on other sites
fla 9 Posted February 4, 2018 Tbh I wouldnt bother with the low temp thermostat. If anything fit a mocal oil cooler, or on a more basic level flush out the system thoroughly using the vw cleaning solution, put a new standard stat in and refill. I would also replace the standard fans with some good slimline ones. Move much more air and use less power! The low temp stat might also make it overfuel Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 4, 2018 Having in the past running a low temp stat I wouldn't do it again. Standard stat all day long. Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
vr6paul 0 Posted February 4, 2018 Thanks for the feedback folks. Flush it may be - and new stat. See how it goes. Low temp switches ? Or not. ? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
fendervg 33 Posted February 4, 2018 No need if it's all working properly and you have all 3 fan stages. Low temp switches and stats will likely just mask other issues that need to be sorted. These cars run hot anyway, but can handle it if the cooling and oil systems are working properly. Quote Share this post Link to post Share on other sites
vr6paul 0 Posted February 4, 2018 Okay cheers. Just remember fans kicking in fairly regular but as said above new coolant/standard stat first off . Cheers . Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
