nas
Corrado won't turn over
Hi guys as title says
Bought this corrado last year been driving it as a daily but as of yesterday nothing
When I bought it it had a push start to start car up so ignition on push start I've undone the steering cowling checked wires all good checked the push start button got power going to it so I thought I would check the starter motor got a cable from jumped it from positive from battery to positive of starter motor but nothing am I right in saying starter motor is dead?
Any help much appreciated
Thanks
Check the earth from the battery to the gearbox / engine block is intact, also the thick wire to the starter is also intact.
Tap the starter body with a hammer too see if you have a bad segment in the starter or the starter is jammed
Put the car in gear and handbrake off and "rock" it back and forth. This might unlock the starter if that's the problem .
Checked earth cables all wires intact tap
the starter motor but still nothing
Done that buddy
Check the battery cables as when I thought I had starter motor problems (replaced with brand new starter) but still had nothing it turned out to be green corrosion on the battery cables and earth. All cleaned up and no problems since (4 years ago)
Sent from my SM-G930F using Tapatalk
Thanks will check that but there is no green corrosion on terminal or starter motor I might just buy a second hand starter motor to eliminate the problem
My understanding is all 02a starter motors are the same?
Thanks
