Vr68bay 10 Posted June 23, 2018 Hi after a really good fan shroud for a corrado vr6, not sure if you can get this from heritage??? Thanks Jamie Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 23, 2018 Hello Jamie. Part number 357 121 207 F £129.00 euros For Corrado VR6 with air conditioning with twin fans (eng code AAA) but says Corrado 1992 to 1995 (so should fit eng code ABV also) Length 690 mm Width 330 mm Depth 73 mm Heritage don't stock it but can order it for you from VW Classic Parts, order time is roughly 3 to 4 weeks. Possibly someone on here may have a secondhand fan cowl / shroud. ****************** Also there's this item the plastic top fan guard, that attaches to the fan shroud. Says for VR6 Corrado 2.9 only (ABV eng code) Part number 535 121 343 C £28.95 euros ******************** Right rad fan unit (Right side when sat in car) Part number 357 119 113 A £159.00 euros Fan diameter 302 mm Fan depth 55 mm Can only see the right fan at the moment for the Corrado VR6 on Classic Parts site. Hope this helps Si Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 23, 2018 (edited) I can confirm what Si says as I bought one and is the same as the one I took off of the car. If you want it quick order direct from classic parts but the postage is horrendous. Edited June 23, 2018 by 1xshaunx1 Quote Share this post Link to post Share on other sites
Geeba 0 Posted June 24, 2018 Si you are 'The Don' when it comes to part numbers! - really helpful as I'm looking for so many bits as well - thank you ;) Quote Share this post Link to post Share on other sites
SamG40 0 Posted July 8, 2018 I've got a shroud with a motor included and the fans attached available. Quote Share this post Link to post Share on other sites
