Stone0311 0 Posted August 13, 2018 Going through my wiring harnesses prior to install with a bit of a tuck, can anyone shed any light on the loose ends below?: > Yellow connector on LH Front wiring harness - would be around the headlight location; returns to a separate plug from the fusebox? > 3 Wire connector on the LH front wiring harness - would be around the exp tank area? (Ignore the previous butchery, not mine) Can find either in the wiring diagrams, so any help appreciated. Cheers Quote Share this post Link to post Share on other sites
STU175 0 Posted August 13, 2018 I cant see your pic but the yellow plug is unused on mine but i do have an uprated headlight loom. The instructions say to unplug it but it was never there on mine. It used to go what i believe to be called a ballast resister some thing to do with headlights. 3 pin plug what wire colours and ill have a look at mine tomorrow for you? Quote Share this post Link to post Share on other sites
Stone0311 0 Posted August 14, 2018 Hi STU175, I remember there being a ballast on the old 16v loom - mine was on the drivers side tho. 3pin plug colours in order - Brown, Green/Blk, Blk/White Thanks Quote Share this post Link to post Share on other sites
STU175 0 Posted August 14, 2018 ive had a hunt around i cant see it anywhere. sorry i tryed.... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 14, 2018 2nd pics looks like the heated windscreen nozzles to me Quote Share this post Link to post Share on other sites
Stone0311 0 Posted August 14, 2018 For clarity the second pic is the fusebox end of the cable in the first - not that it sheds a lot of light The one with the 3pins is in the same location as the exp tank sensor plug Quote Share this post Link to post Share on other sites
