GrahamV 10 Posted September 24, 2018 (edited) Corrado VR6 & Others original serviceable Used and some NEW as listed, parts to clear Regards Graham V [ATTACH=CONFIG]95180[/ATTACH] [ATTACH=CONFIG]95178[/ATTACH] [ATTACH=CONFIG]95179[/ATTACH] [ATTACH=CONFIG]95181[/ATTACH] 1 Aerial mast OE look without spiral wire NEW £9.00 1 set Lowering Springs, both Front & rear Eibach as NEW https://www.vwheritage.com/wc412e8513140-eibach-suspension-coil-spring-kit-25mm-lowered-vw-spare @£160.00 set inc carriage. Actual lowering from 1993 OE spec is more like 40mm-50mm front and rear and gives a very good ride too. 1 pair Front strut mounting top bush NEW OE (not vr) 357 412 329 @£40 pair 1 VR6 & Storm Rear die cast badge set- being prepped and black/red painted when I get time £tba 1 Radiator main fan motor assembly OE 3 stage,4 pin, 357 959 455L £20.00 RESERVED Rogerb 1 Radiator temp sensor £2.00 1 Coolant temp sensor 4 pin blue NEW@£4.00 1 Oil pressure sensor NEW £3.00 1 Heater Foliage fresh air mesh pollen filter plastic cover £4.00 20 Wheel bolts M12 x 1.5 NEW MK1, (not VR) 4 bolt pattern £6.00 set 1 Exhaust silencer round, fits after CAT pattern part NEW £6.00 carriage on this is £14.00 1 Scuttle water tray seal rubber 535 819 521 front one @£5.00 1 RH Inner door drop glass felt scraper seal £10.00 Collect only for glass- 1 RH door Drop Glass Green film tint 535845022 NEW OE £50.00 1 LH door Drop Glass Green tint 535845021A £10.00 2 RH door Drop Glass Green tint 535845022A £10.00 1 Tailgate glass green tint 2 filaments need easy repair 535845501A £20.00 RESERVED RogerB 2 LH door side moulding bump protector NEW NOS MK1 535 853 515 2BC £12.00ea (MK1 suit G60, not so deep as VR6 onwards MK2) 1 RH rear 1/4 side moulding bump protector black £15.00 1 RH wing side moulding bump protector black £6.00 1 Power steering pump VR6 535 145 157 requires refurbishment £30.00 (Current VW OE part no. 6N0145157X is £360 new plus £120 exchange surcharge) 1 Indicator stalk no hazard cowl £5.00 1 LH Mirror Casing, black trim broken and no motor (fits TVR’s) £7.00 1 Fuel flap rubber retainer wire £1.00 1 Gear box selector plastic remote guide NEW £5.00 1 Gear box overhaul parts-1st syncro and others NEW £15.00 set 1 Air box hose 100mm clip NEW£2.00 2 Servo vac hose clips NEW £1.00 1 Door check strap foam £1.00 1 set Bumper Lifting bars £110.00 collect only. Can be used to lift car, or when fitted to a CJ Autos CT04 can be fully rotated upside down.https://www.cjautos.eu/Standard_NBN_chassis_tilter_p/ct04.htm Collection-North Staffordshire ST13 or post at cost using Royal Mail/parcelforce normally £4 to £17. Edited November 27, 2018 by GrahamV Update Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted September 24, 2018 (edited) 1 Power steering pump 535145157 for refurbishment- current VW part no. 6N0145157X exact as Polo-(VW is £100 surcharge) £30.00 Is this brand new refurbished ? If so 100% interested is it for a Vr Edited September 24, 2018 by Jon_vr6 Quote Share this post Link to post Share on other sites
GrahamV 10 Posted September 24, 2018 Sorry, no not working 100%, so requires refurbishment or could be used as exchange to avoid delay on VW surcharge refund. Note: Most after market ones on eBay are incorrect and VW is £350 plus £120 surcharge Jon_vr6 said: 1 Power steering pump 535145157 for refurbishment- current VW part no. 6N0145157X exact as Polo-(VW is £100 surcharge) £30.00 Is this brand new refurbished ? If so 100% interested is it for a Vr Quote Share this post Link to post Share on other sites
lawyer6 10 Posted September 25, 2018 Are the Radiator temp sensor, Coolant temp sensor 4 pin blue, Oil pressure sensor, RH Inner door drop glass felt scraper seal, new or used? Can I have a pics of the Scuttle water tray seal rubber 535819521 and VR6 & Storm Rear die cast badge set Unused? You can reach me on rocco9933@hotmail.com. Cheers mate. Quote Share this post Link to post Share on other sites
GrahamV 10 Posted September 25, 2018 Rad sensor is used Coolant sensor 4pin and oil are new Inner felt used Scuttle rubber is in pics it’s the one that goes on rainwater tray lip. Storm badges are now being painted black/red and listing revised. Pic is in my other sold-VR6 parts for sale thread Let me know if this is sufficient info as items in storage away from home. lawyer6 said: Are the Radiator temp sensor, Coolant temp sensor 4 pin blue, Oil pressure sensor, RH Inner door drop glass felt scraper seal, new or used? Can I have a pics of the Scuttle water tray seal rubber 535819521 and VR6 & Storm Rear die cast badge set Unused? You can reach me on rocco9933@hotmail.com. Cheers mate. Quote Share this post Link to post Share on other sites
lawyer6 10 Posted September 28, 2018 Id be interested in the coolant sensor, oil sensor and the badges. Let me know wen you have a price for all. Quote Share this post Link to post Share on other sites
Virdee 10 Posted November 17, 2018 2 Suspension front turret top blank caps as new 1H0412359 £ 5.00 pair Still available? Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 18, 2018 Virdee said: 2 Suspension front turret top blank caps as new 1H0412359 £ 5.00 pair Still available? Yes, still available. Will PM details List of parts is up to date Quote Share this post Link to post Share on other sites
Stormy_VR 10 Posted November 26, 2018 I’ll take the first aid box, posted if still available please. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 26, 2018 Did the turret tops sell Graham?. Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 26, 2018 Stormy_VR said: I’ll take the first aid box, posted if still available please. Yes, will pack ready and send you PayPal details Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 26, 2018 robrado974 said: Did the turret tops sell Graham?. No still available, will PM you PayPal details later. Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 26, 2018 Hello Roger Blassberg, Just wondered if you are coming this way and be able to collect the tailgate glass, rad fan motor assv etc. at some time. The parts are at ST13 7AP and I am close by too Should things have changed for you and no longer need the items just let me know as I am now moving my car parts to another location Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 28, 2018 20 Wheel bolts M12 x 1.5 NEW MK1, (not VR) 4 bolt pattern £6.00 set 1 Gear box selector plastic remote guide NEW £5.00 Hi Graham can I take these mate? Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 28, 2018 GrahamV said: No still available, will PM you PayPal details later. Paid . Thanks Graham. Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 28, 2018 robrado974 said: Paid . Thanks Graham. Despatched today Cheers Quote Share this post Link to post Share on other sites
GrahamV 10 Posted November 28, 2018 lilfuzzer said: 20 Wheel bolts M12 x 1.5 NEW MK1, (not VR) 4 bolt pattern £6.00 set 1 Gear box selector plastic remote guide NEW £5.00 Hi Graham can I take these mate? Yes, Will pack and dispatch with PM PayPal details Cheers Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 29, 2018 GrahamV said: Despatched today Cheers Thank you Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 30, 2018 Received today , thanks Graham. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted December 12, 2018 Very sorry to keep you hanging on Graham. I do still want the rear screen and the fan motor. I will arrange collection very soon. Thanks for your patience. Best wishes Roger Quote Share this post Link to post Share on other sites
Andy76 10 Posted December 22, 2018 Hello Graham, Can I take one of the LH door side mouldings please? I assume the RH mouldings are later MK2? Thanks Andy Quote Share this post Link to post Share on other sites
Mikey-Mike 10 Posted January 7, 2019 If any of these parts are still on your shelf I will take them please 1 Radiator temp sensor £2.00 1 Coolant temp sensor 4 pin blue NEW@£4.00 1 Oil pressure sensor NEW £3.00 1 Fuel flap rubber retainer wire £1.00 Quote Share this post Link to post Share on other sites
GrahamV 10 Posted February 11, 2019 Roger Blassberg said: Very sorry to keep you hanging on Graham. I do still want the rear screen and the fan motor. I will arrange collection very soon. Thanks for your patience. Best wishes Roger Hi, understood that’s fine, just we are moving into another property and go parts in various locations, so let me know soonest, thanks Quote Share this post Link to post Share on other sites
GrahamV 10 Posted February 11, 2019 Andy76 said: Hello Graham, Can I take one of the LH door side mouldings please? I assume the RH mouldings are later MK2? Thanks Andy Will make sure and confirm, Apologies for late replies as in middle of moving property Quote Share this post Link to post Share on other sites
GrahamV 10 Posted February 11, 2019 Mikey-Mike said: If any of these parts are still on your shelf I will take them please 1 Radiator temp sensor £2.00 1 Coolant temp sensor 4 pin blue NEW@£4.00 1 Oil pressure sensor NEW £3.00 1 Fuel flap rubber retainer wire £1.00 Will check and confirm parts available in next few days Apologies for late reply Quote Share this post Link to post Share on other sites
