Ray1965 10 Posted December 18, 2018 Can i get some advise on this im sure it will be ok. https://www.eurocarparts.com/ecp/c/Volkswagen_Corrado_2.9_1995/p/car-parts/transmission-parts/car-transmission/wheel-bearing-and-wheel-hub/?628440651&1&7360aa29818d623d973e79d3123b05b0fb1081ec&000370 Quote Share this post Link to post Share on other sites
delfinis38 1 Posted December 18, 2018 Go for snr or skf.... better quality Quote Share this post Link to post Share on other sites
Simeon 0 Posted December 19, 2018 I've used these in the past, no issues, good quality and cheap https://www.ebay.co.uk/itm/VW-CADDY-CORRADO-GOLF-JETTA-PASSAT-POLO-VENTO-Front-Axle-Wheel-Bearing-Kit-FAG/232978240082?fits=Model%3ACorrado&epid=249025293&hash=item363e95d252:g:W6AAAOSwvdxbvgdM:rk:1:pf:0 Quote Share this post Link to post Share on other sites
culshaw 1 Posted December 19, 2018 (sorry for hijack) Out of interest, what grease do people use for wheel bearings (mainly rear)? I've bought some 3-in-1 white lithium grease, will that be good enough, it doesn't seem gloopy enough Quote Share this post Link to post Share on other sites
a_riot 0 Posted December 20, 2018 (sorry for hijack) Out of interest, what grease do people use for wheel bearings (mainly rear)? I've bought some 3-in-1 white lithium grease, will that be good enough, it doesn't seem gloopy enough There is a special grease called wheel bearing grease, usually available at most auto repair stores. Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 20, 2018 It doesn't have to be specific wheel bearing grease. Most CV or high temp greases can be used. You usually get a little sachet of it in with new bearings, though I prefer to use a bit more tbh. Quote Share this post Link to post Share on other sites
culshaw 1 Posted December 20, 2018 It doesn't have to be specific wheel bearing grease. Most CV or high temp greases can be used. You usually get a little sachet of it in with new bearings, though I prefer to use a bit more tbh. I've got this one which looks the ticket, but it's really thin https://3-in-one.co.uk/products/white-lithium-grease/ but I've just bought this, hopefully it has a bit more gloop to it. https://www.amazon.co.uk/Comma-BG2500G-Performance-Bearing-Grease/dp/B007WR38TY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1545307472&sr=1-1&keywords=wheel+bearing+grease Quote Share this post Link to post Share on other sites
Dox 23 Posted December 20, 2018 Its important to install them correctly, once refitted hold the wheel at 3 and 9 o'clock and rock it side to side, if there's no play its too tight and any grease will be squeegeed away and the bearings will score the races leading to premature failure. Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 20, 2018 Yeah the comma stuff will do perfectly. As mentioned by by Dox, don't overtighten (especially the tapered rear ones) as it'll score the races/stub axle. I know from experience! lol. Quote Share this post Link to post Share on other sites
a_riot 0 Posted December 23, 2018 I wouldn't use moly grease in a wheel bearing subject to high speeds. "Greases containing moly are recommended for roller bearings subjected to very heavy loads and shock loading, especially in slow or oscillating motion such as found in universal joints and CV joints. If such greases are used in high-speed bearings, problems can be experienced with roller “skidding” where the bearing roller fails to rotate through the full 360 degrees due to reduced friction. As a result, the roller develops flat spots, and its service life is reduced." Quote Share this post Link to post Share on other sites
