k993apc
please delete mods
Hi Bryan,
Congrats on your purchase, and welcome to the forum. What is the fan problem that you're having? There are a few known fan problems depending on your symptoms. Let us know what you're experiencing and we'll try to help where we can. For info, Stealth racing in Southam aren't too far from your general area. They're one of if not the, most knowledgeable professionals in the UK for all things Corrado.
They always come on together they are joined by a belt only one is powered, just at different speeds depending on temperature. They are loud at full pelt. Look in the definitive cooling guide in the engine section for a very good write up detailing sensors and temps.
Did you try bridging the plug that goes to the sender in the rad like the guide suggests. If your Uber loud fans are comming on at 110 degrees ish on you dash water temp and nothing before then it would suggest there is something wrong with that sensor or the wiring connected with it from the radiator.
When you bridge the plug the fans should come on but not as fast and boomy, bridge the other wire and should get faster, if it’s doing that it’s got to be the sensor as the rest of the system is doing what it should. Maybe the switch over temps on that sensor are different to what they should be. If it’s not doing the above things with fans when bridging then your problem is between the plug and the fan control unit including this.
