FrankyEight
Help required diagnosing problem please
Hi guys
I've got a '94 2.0 16v which has the following issue; once the car get's up to temperature, the idle rises from normal (750rpm ish) to 1000rpm and stays there until I 'reset' it by switching off engine and back on again. Even then, after a few minutes of driving it'll rise back up to 1000rpm. I've been told this might be the ISV (idle stabilisation valve?. If so, could someone advise how I remove this and clean it and refit (I'm clearly a novice!). Also, I've been reading that it may be the temperature switch or thermostat? I'm not sure of the difference, again some advice on what the difference is and how they can be replaced would be greatly appreciated.
Many thanks in advance!
IMHO it's much more likely this is a result of a sensor fault on the engine. Do you have accecss to a diagnostic code reader? VAG-COM or one of the older two-wire diags tools should be able to query the 2.0 16v engine iirc.
Thanks for your reply dr_mat — I don't have access to VAG-COm or the other diags tools... do general garages have this equipment or should I find a VW specialist who does? I'm in Surrey. Cheers!
Thanks — post is really interesting and sounds just like my issue — do you know where the temperature sensor for the engine management system is located exactly so I can check and replace if necessary? Thanks for your patience...
I believe they're usually on the thermostat housing, but that might just be the VR6 I'm thinking of!
Thanks. Regarding VAG-COM, I might buy a generic reader from eBay or somewhere. They all seem to be SCART. Do I need a 4-pin adapter for this or do I need a specific 4-pin Reader? Cheers again!
Think I've found an adapter!
Check the compatibility. Even the early VWs with the SCART-type connector didn't actually speak full OBD2 protocols so the reader needs to be aware of this. I've never attempted to get one for a 2.0 16v. You can still get the 4-pin adapters with USB connected dongles that will work with the old 3.11 version of VAG-COM (which is still free from what I recall).
Could be an air leak? Check all vacuum piping around the engine bay going too / from the manifold etc for splits etc allowing air to enter the engine when the throttle is closed
