captainredeye 0 Posted January 28, 2019 I have had an issue with the 2nd stage not coming on, I have replaced the fan control module with no luck and have now removed the loom to check for any damage. My question is would the actual fan have a fault where by the second stage has stopped working and the fan has the speeds built into it and the fan module is just a sort of switch or is the fan speed controlled by the module? Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 28, 2019 Based on this: http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide ...it could be you radiator temp sensor or the 4-pin yellow sender in the thermostat housing, unless you have already ruled them out. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted January 28, 2019 You need to turn the ignition on and bridge the 3 pin plug on the bottom of the radiator as described in the guide. If you don’t get the 2 stages to come on as in the guide it’ll be the wiring or the fan control unit where all the wiring goes to. The yellow sensor is for dash temp and after run. Stage 3 is off the black plug in the thermostat housing. Bridging the plug does work as it’s how I diagnosed my sender being duff as my stage 1 doesn’t work but when I bridge the plug it comes on great. Quote Share this post Link to post Share on other sites
captainredeye 0 Posted January 28, 2019 Well i have bridged the pins and stage 1 is there but not 2, i replaced the module as a couple of diodes had fallen off inside but still no joy, i have removed the loom and have found breaks which are now repaired i will fit it soon and see if i have any luck with it, i was just a little unsure if there was also the speeds built into the fan but im guessing than is controlled by the current so it can't be the fan at fault. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted January 29, 2019 The fan controls the 3 speed but if stage 2 had gone so would stage 3... I think. Basically you have 3 positives and a negative going in, stage 1 goes through 2 resistors, stage 2 goes through 1 and stage 3 is direct 12v. But sounds like you've sorted it anyway Quote Share this post Link to post Share on other sites
captainredeye 0 Posted February 3, 2019 Ok, i have tidied up and repaired the loom after removing it i have every thing back in apart from the black plug with the thick red wire which i can't work out where it goes, im not sure if its directly into the back of the fuse box or if there is a wire with the connecting plug hanging around somewhere but i can't see it, any ideas? Quote Share this post Link to post Share on other sites
