culshaw
Rear passenger side carrier
Same as MK3 Golf etc
Tap yours with a hammer to break the rusts hold, then remove the slide pins and wire brush / emery cloth them until clean. Scrape the orifices in the carriers of the rust using a drill bit, clean, lube with grease and refit the dust covers
Thanks, I saw these but wasn't certain it was the right carrier
My ones aren't only stuffed with rust. I cleaned them and lubed, but some plank has painted the rubber grommets too
Mine were like that when I got it too. Seems the PO just used a brush to slap on the carrier and caliper paint everywhere, including the boots and pads!
You should be able to clean it all up, and copper grease the slider pins. Replacement boots are pence.
