will 2 0 Posted June 16, 2020 looking for a fuel pump to fit my 2.0 16v and the price ranges are vast, from about £35 upto way over £200 for a bosch , what make would you guys recommend or actually use. and also the same question for the accumulator, part numbers if poss if you can. thanks Quote Share this post Link to post Share on other sites
fendervg 32 Posted June 16, 2020 Bosch/VDO/Siemens and Pierburg are all good makes - after that you are into buyer beware territory and cheap Chinese copies. To be honest, 100-200 for a quality pump would be normal and there's nothing worse than a fuel pump failure while driving. The VR6 VDO pump can cost as much as 400 squids. Is your 16V pump set up a lift pump in the tank and a main pump underneath? I'd expect to pay about 100 or so for a decent lift pump. Quote Share this post Link to post Share on other sites
will 2 0 Posted June 16, 2020 1 minute ago, fendervg said: Bosch/VDO/Siemens and Pierburg are all good makes - after that you are into buyer beware territory and cheap Chinese copies. To be honest, 100-200 for a quality pump would be normal and there's nothing worse than a fuel pump failure while driving. The VR6 VDO pump can cost as much as 400 squids. Is your 16V pump set up a lift pump in the tank and a main pump underneath? I'd expect to pay about 100 or so for a decent lift pump. hi , yes lift pump in the tank, with the main underneath, whats your thought on the accumulator Quote Share this post Link to post Share on other sites
