blue95 0 Posted September 29, 2020 (edited) Hello all, Whilst sorting my replacement engine harness (95 VR6) i noticed on my old loom that the wiring for my Throttle position Sensor had been altered, in particular the brown/green wire had been earthed....just wondered why this would need to be done? as the wiring looked OK, assume the the other end is earthed somewhere Edited September 29, 2020 by blue95 Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 29, 2020 (edited) Sounds strange - I would have thought the TPS was variable resistance, so one wire is + and the other -, with the ECU interpreting the difference - surely a separate earth straight to ground would mess this up? Do you have any pictures? Or could it be that your previous loom was for a motorised throttle on OBD2, maybe a AAA engine transplant from a Golf? Edited September 29, 2020 by fendervg Quote Share this post Link to post Share on other sites
blue95 0 Posted September 29, 2020 (edited) Green/White - Throttle Position Sensor Signal? Black/Gray - Throttle Position Sensor Power? Brown/Green - earth Plan to trace the Brown/Green wire to see where it goes to originally as well - can only assume root cause was bad earth but id like to be sure. Dont plan to emulate on my newer loom Edited September 29, 2020 by blue95 Quote Share this post Link to post Share on other sites
tonedef 10 Posted September 29, 2020 (edited) If you look at the following pinout for the OBD1 VR6 ECU you'll see these allocations: Pin 40 TPS signal 1 Green/White Pin 41 TPS Power Black/Grey Pin 33 Sensors Ground (including Throttle) Brown Click I also have a Golf wiring diagram which shows the same wiring,: TPS pin 1 to plug T42 pin 28 Brown/Green which joins a group of other Brown/(Second Colour) wires before becoming finally a brown which goes to ECU plug T68 pin 33 TPS Pin 2 to plug T42 pin 29 Green/White to ECU plug T68 pin 40 TPS pin 3 to plug T42 pin 34 Black/Grey to ECU plug T68 pin 41 Admittedly it's not a Corrado diagram but I've swapped enough looms around to know they generally follow, it suggests your wiring whilst maybe not the neatest is correct as installed. Edited September 29, 2020 by tonedef Quote Share this post Link to post Share on other sites
blue95 0 Posted September 30, 2020 Cheers, traced the wire back goes to the multiplug, the old loom did have a few cracks and the wire was corroded, so assume there was a bad earth at some point which led to this fix. Quote Share this post Link to post Share on other sites
fendervg 33 Posted September 30, 2020 On 9/29/2020 at 10:01 PM, tonedef said: If you look at the following pinout for the OBD1 VR6 ECU you'll see these allocations: Pin 40 TPS signal 1 Green/White Pin 41 TPS Power Black/Grey Pin 33 Sensors Ground (including Throttle) Brown Click I also have a Golf wiring diagram which shows the same wiring,: TPS pin 1 to plug T42 pin 28 Brown/Green which joins a group of other Brown/(Second Colour) wires before becoming finally a brown which goes to ECU plug T68 pin 33 TPS Pin 2 to plug T42 pin 29 Green/White to ECU plug T68 pin 40 TPS pin 3 to plug T42 pin 34 Black/Grey to ECU plug T68 pin 41 Admittedly it's not a Corrado diagram but I've swapped enough looms around to know they generally follow, it suggests your wiring whilst maybe not the neatest is correct as installed. Ah ok - so it's 3 wires at the TPS plug then - serves me right for being too lazy to open the bonnet in the rain the check! Looks like it was just a workaround for a bad earth then, to avoid having to inspect the whole loom and fix. Quote Share this post Link to post Share on other sites
