mooG60 11 Posted January 5, 2021 I've been told that if the rear engine mount fixing bolts snap on removal that the engine would have to be removed to fix it properly. PG Engine Can any one deny or confirm this for me please? Cheers Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted January 5, 2021 I cannot confirm or deny - I suppose it depends what bolt(s) have snapped and access to the area. There isn't that much room to get your hands there _and_ see what's going on - even if the inlet bits are removed from above. Hope it helps Quote Share this post Link to post Share on other sites
mooG60 11 Posted January 7, 2021 Thank you Philly My mechanic managed to do it today thankfully. There is one long bolt which was seized, he said he had to remove the drive shaft to get room enough to get at it. No more thud noise when I give it some welly. Cheers Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 8, 2021 15 hours ago, mooG60 said: Thank you Philly My mechanic managed to do it today thankfully. There is one long bolt which was seized, he said he had to remove the drive shaft to get room enough to get at it. No more thud noise when I give it some welly. Cheers A great result in the end 👍 Quote Share this post Link to post Share on other sites
