LA9V VR6
021 906 258 AG ECU - immobiliser??
Hi, does any know if ecu 021 906 258 AG has an immobiliser?
Changed loom today and it fired up, but then cut out.
Fuel pump also sometimes primes and then other times primes and stops after about 2 seconds.
thanks
I think its just the CP suffix ecus with the built in immobiliser, not AG, although those symptoms you describe are very much immobiliser type issues
So AG definitely does not have an immobiliser?
Would the fuel pump prime at all though,  if it was an immobiliser issue?
I'm going to go through the loom again tomorrow as I think it may he a fuel pump wiring issue...
RPMs on tachometer yet?
no crank position to ecu and the pump won’t run beyond priming
Yes,  rpms on clocks once it fires into life.
Do you know what wire/ plug in fuse box I can check?
Im glad to see you've made some progress re RPMs. Personally I'd remove the pump relay and test it.
I'd also see if the power getting to the fusebox and if its maintained on cranking engine started the engine and the key position returns to the usual run position (I'm sure the ecu provides the earth to the relay, so you need to check for earth too).
Can't find much, but found this video on youtube
2 mins in
Edited by Dox
As Dox mentions, can you check the fuel pump relay ( numbered either 167 or 67) and the ecu relay (109)?  Just apply a 12v source to them and ensure they close, and more importantly stay closed.  If so then that will confirm their condition.  Also check the connectors at the back of the fuse box - there is a plastic 'lock' bar that hold all connectors in place once seated.  The connectors should all be in a line, and not protruding - if the latter, this connector is then loose.
Just another thought - when it starts, what happens if you give it some gas to increase the revs?  Does it still die or will it then continue running?
Keep us posted on how you get on
