lewvr6 0 Posted January 3, 2025 Hi guys I’m wondering if you are able to help me with this ongoing issue with my vr6 AAA obd1 it ran perfectly fine for a while and I took it out one night and it just started bogging down and wouldn’t hold idle, so I got it home real quick before it broke down and looked at it the next day. now it will no longer idle at all unless I hold the throttle down but even then I can feel it misfiring i had to change my clutch at some point anyway so I thought this is a good time to do my timing and pull the engine while I do it. so I go and change my clutch and check my timing and behold it has already been done!!! There is no slack in the chain and it all lines up anyway I put the engine in and before getting it plugged in, I decide to clean all the big block connector terminals because I’m grasping at straws on why it doesn’t run then I change out my temp sensor and the other yellow one long story short it still will not idle unless I hold the throttle down https://youtube.com/shorts/yCSc1P4ZfFY?si=ZQj5IaAlv9UZLknQ That’s a video of it attempting to run^^ Any help would be GREATLY appreciated I’ve slowly been changing everything on this car because everything seems to be breaking on me within a month of getting it running again so far over the span of 2 years I have done new coil pack new idle control valve new pvc filter thing new crank sensor new hall sensor new fuel pump changed ecu (apparently electrics don’t like having water on them😭😭) new coolant sensors new iat sensor new tps sensor refurbished injectors new MAF!!!! (Old ones metal mesh thing was ripped up and I didn’t wanna risk a metal bit going into my engine) new ht leads and spark plugs (done that like 2 months ago) new fuel filter (literally 3 hours ago) I knew having a 30 year old car will give me issues but come on this is ridiculous I think I’ve got a lemon😭😭 Oh and just before posting I thought i better add this The day after I put the different ecu on the car I took it out for a spin and it just SHUT OFF on me and started leaking petrol everywhere i had a leaky injector that overfilled so much it came out of my air box I was just lucky it didn’t catch fire I reckon anyway the fuel tank did run DRY so I’m wondering if my new fuel pump is now slightly nackered??! and yes I did change all the spark plugs and oil and oil filter afterwards Quote Share this post Link to post Share on other sites
fendervg 33 Posted January 4, 2025 Sounds like you have a vacuum leak - you can measure your manifold pressure off one of the vac hoses using a t-piece for a pressure gauge or by connecting to one of the little test outlets. Also, have you checked your accelerator cable to make sure it's secure and not slipping or stretched? Quote Share this post Link to post Share on other sites
Dox 31 Posted January 4, 2025 OBD1 cars run like a bag of shite if the battery has been disconnected / gone flat, it takes several drive cycles to settle down as the eco needs to relearn the perimeters of the sensors. Randomly disconnecting sensors puts the eco into limp exaggerating your stall issues. Battery off over night, drive for several days without tinkering, then review the issues you have Quote Share this post Link to post Share on other sites
Bruno 4 Posted January 6, 2025 The lambda probe when faulty causes exactly the problem you have. Removing the TPS plug puts the ECU into limp mode and the ECU disregards what the lambda probe says. To confirm you need to obtain the obd error messages. Quote Share this post Link to post Share on other sites
